Ana içeriğe geç
GBC Creative Laminator Motor Replacement
Neye ihtiyacın var
  1. GBC Creative Laminator Motor Replacement, Motor: adım 1, 2 resimden 1. GBC Creative Laminator Motor Replacement, Motor: adım 1, 2 resimden 2.
    • Using the Phillips #2 screwdriver, remove ten 12 mm long screws on the bottom of the device.
  2. GBC Creative Laminator Motor Replacement: adım 2, 1 resimden 1.
    • Open the top of the device, and the inside of the Laminator will be exposed as shown.
  3. GBC Creative Laminator Motor Replacement: adım 3, 2 resimden 1. GBC Creative Laminator Motor Replacement: adım 3, 2 resimden 2.
    • Using the Phillips #2 screwdriver, remove two 9 mm long screws on the side of the main component that keep the motor in place.
  4. GBC Creative Laminator Motor Replacement: adım 4, 2 resimden 1. GBC Creative Laminator Motor Replacement: adım 4, 2 resimden 2.
    • Using the Phillips #2 screwdriver, remove three 8.5 mm long screws and washers on the front edge of the plastic casing.
  5. GBC Creative Laminator Motor Replacement: adım 5, 1 resimden 1.
    • Lift the motor out of the plastic casing.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Yujia Tang
384 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G1, Wilson Summer 2018 IUPUI, Team S1-G1, Wilson Summer 2018 üyesi
IUPUI-WILSON-SU18S1G1
5 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 822
