Ana içeriğe geç
GD Midea FT30-3D Fan Blades Replacement
Neye ihtiyacın var
  1. GD Midea FT30-3D Fan Blades Replacement, Fan Blades: adım 1, 2 resimden 1. GD Midea FT30-3D Fan Blades Replacement, Fan Blades: adım 1, 2 resimden 2.
    • Release the 3 clips that attach the front fan guard to the rear fan guard.
    • Notice: The lower connecting bracket is NOT a clip. It acts as a mounting alignment bracket for the front fan guard.
  2. GD Midea FT30-3D Fan Blades Replacement: adım 2, 1 resimden 1.
    • Pull the front fan guard off.
  3. GD Midea FT30-3D Fan Blades Replacement: adım 3, 2 resimden 1. GD Midea FT30-3D Fan Blades Replacement: adım 3, 2 resimden 2.
    • Remove the spinner from the center of the fan blade.
    So how do i take the spinner off the fan
    Martha Meza - Yanıt
    H how do I take the spinner off the center of a fan I don't know how
    Martha Meza - Yanıt
  4. GD Midea FT30-3D Fan Blades Replacement: adım 4, 1 resimden 1.
    • The fan blades should now be easy to lift up.
    • When reassembling the fan make sure the notches in the center of the fan blade line up with the protrusions in the motor's shaft.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Alan Su
810 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-28, Regan Fall 2012 Cal Poly, Team 24-28, Regan Fall 2012 üyesi
CPSU-REGAN-F12S24G28
4 Üyeler
14 adet Kılavuz yazıldı
Bir Yorum
Where do you buy the fan blades?
charlie - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 18
Her zaman: 3,229
