Ana içeriğe geç
GE 29875GE1 Microphone Replacement
Neye ihtiyacın var
  1. GE 29875GE1 Microphone Replacement, Remove the Form Pads: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Begin by looking at the bottom face of the device. Use the tweezers to remove the four foam pads which are covering four screws
  2. GE 29875GE1 Microphone Replacement, Remove the Screws: adım 2, 1 resimden 1.
    • Use the #2 philips screwdriver to remove the four screws from the bottoms of the device. These screw heads are sized 5.3mm or .209 in
  3. GE 29875GE1 Microphone Replacement, Opening the Device: adım 3, 1 resimden 1.
    • Remove the back casing panel by gently pulling back until you are able to reach the inside. gently pull the microphone out of its housing. This is only held in by friction so its easy to remove
  4. GE 29875GE1 Microphone Replacement, Locate Wires: adım 4, 1 resimden 1.
    • Locate the two wires attached to the microphone. The wires are attached to the back of the motherboard and are brown and black.
  5. GE 29875GE1 Microphone Replacement, Soldering: adım 5, 1 resimden 1.
    • Using the soldering station and soldering iron unsolder the two pins holding the microphone in place
  6. GE 29875GE1 Microphone Replacement, Replace Microphone: adım 6, 1 resimden 1.
    • Pull out the old microphone and discard it the correct way. Place the new microphone in the same spot the old one was in. Solder the new microphone to the correct pins
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Mykaliah Best
211 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-6, Miles Fall 2014 UMass Dartmouth, Team 4-6, Miles Fall 2014 üyesi
UMASSD-MILES-F14S4G6
3 Üyeler
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 30
Her zaman: 380
