Ana içeriğe geç
GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement
Neye ihtiyacın var
  1. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Battery Compartment Cover: adım 1, 3 resimden 1. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Battery Compartment Cover: adım 1, 3 resimden 2. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Battery Compartment Cover: adım 1, 3 resimden 3.
    • Find the battery compartment on the bottom of the clock radio.
    • Using your thumb, push the compartment cover latch toward the battery.
    • With the latch pushed in, pull the compartment cover upward to remove it..
  2. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Battery: adım 2, 2 resimden 1. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Battery: adım 2, 2 resimden 2.
    • Lift the battery from the compartment.
    • Pull the battery up and gently disconnect it from the battery connector.
  3. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Screws: adım 3, 2 resimden 1. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Screws: adım 3, 2 resimden 2.
    • Using a Phillips #00 Screwdriver, unscrew the six 12mm screws from around the bottom of the clock radio.
  4. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, LCD Cover: adım 4, 1 resimden 1.
    • Gently pull the liquid crystal display (LCD) cover off.
  5. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Clock Radio: adım 5, 2 resimden 1. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Clock Radio: adım 5, 2 resimden 2.
    • Lift the top off. Two gray, plastic internal pieces will fall out when you do this; set them aside.
  6. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Speaker: adım 6, 2 resimden 1. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Speaker: adım 6, 2 resimden 2.
    • Grip the speaker.
    • Lift the speaker from the holder.
    • Turn the speaker over.
  7. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Speaker from Wires: adım 7, 3 resimden 1. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Speaker from Wires: adım 7, 3 resimden 2. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Speaker from Wires: adım 7, 3 resimden 3.
    • The red wire is the + and the tan wire is the -. These wires are connected with solder.
    • Apply the hot soldering iron tip to the speaker connection solder.
    • Pull the speaker away from the wires.
  8. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, New Speaker: adım 8, 3 resimden 1. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, New Speaker: adım 8, 3 resimden 2. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, New Speaker: adım 8, 3 resimden 3.
    • Attach a new 65 mm speaker, model #115048352530, with the wire connectors. Match the red wire to the + and the tan wire to the -.
    • Solder the wires to connect. Let the solder cool.
    • Reverse Step 6 to insert the new speaker in holder.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Dominick Giguere
848 İtibar
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 25
Her zaman: 1,947
