Ana içeriğe geç
GE A1050 LCD Replacement
Neye ihtiyacın var
  1. GE A1050 LCD Replacement, LCD: adım 1, 3 resimden 1. GE A1050 LCD Replacement, LCD: adım 1, 3 resimden 2. GE A1050 LCD Replacement, LCD: adım 1, 3 resimden 3.
    • Remove the batteries, hand strap, and memory card if so equipped.
    • Remove the two Phillips screws from the bottom.
    • Remove the two Phillips screws from the left side.
    FixBot'a Sor
    Yorum Ekle
  2. GE A1050 LCD Replacement: adım 2, 3 resimden 1. GE A1050 LCD Replacement: adım 2, 3 resimden 2. GE A1050 LCD Replacement: adım 2, 3 resimden 3.
    • Remove the two screws from the right side.
    • The two screws from the left side are shorter than the ones from the right. Keep those separated.
    • Start splitting the case from the battery compartment to the sides. No special tool is needed to split the case.
    FixBot'a Sor
    Yorum Ekle
  3. GE A1050 LCD Replacement: adım 3, 3 resimden 1. GE A1050 LCD Replacement: adım 3, 3 resimden 2. GE A1050 LCD Replacement: adım 3, 3 resimden 3.
    • Do not remove the back side of the case, just flip it over. The speaker is connected by wires to the main body, but positioned in the back case.
    • Flip the LCD to the bottom. You can not yet remove it, because it is still attached to the board.
    • The LCD cable is held into the connector via some compression clips. Move both ends carefully away from the connector, toward the LCD.
    • The clips only move about an 1/8 of an inch. Be careful not to use too much force.
    FixBot'a Sor
    Yorum Ekle
  4. GE A1050 LCD Replacement: adım 4, 1 resimden 1.
    • After exchanging the LCD for a new one, and after reassembling your camera, you should have a working LCD.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
oldturkey03
856.826 İtibar
123 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 49
Her zaman: 2,499
