Ana içeriğe geç
GE Washing Machine Agitator Replacement
Video Kılavuzu
Bu kılavuz bir YouTube videosundan alınmıştır.
Neye ihtiyacın var
      • Raise the lid to give full access to the agitator assembly.
      FixBot'a Sor
      Yorum Ekle
      • Look for the small round hole located at the very bottom of the agitator skirt.
      • This hole is the only place where a tool can lock the agitator for removal.
      FixBot'a Sor
      Yorum Ekle
      • Feel around the agitator base until you find the raised nipple on the washer plate.
      • Rotate the agitator until its hole lines up directly over the nipple.
      • Removal will not work unless these two features line up exactly.
      FixBot'a Sor
      Yorum Ekle
      • Insert a Phillips screwdriver through the hole and press it in until it bottoms out.
      • Push the screwdriver in deeply so it fully engages the mechanism.
      FixBot'a Sor
      Yorum Ekle
      • Have a helper hold the washer tub steady so it cannot rotate while you twist the agitator.
      • If working solo, brace the tub with your free hand while keeping the screwdriver seated.
      FixBot'a Sor
      Yorum Ekle
      • Grip the agitator housing and turn it clockwise until it breaks free from the drive tabs.
      • Lift the agitator straight up and out of the tub once it releases.
      FixBot'a Sor
      Yorum Ekle
      • If you need hub access, remove the central 7⁄16-inch bolt with a socket wrench and lift off the plate.
      FixBot'a Sor
      Yorum Ekle
      • Align the four slots on the agitator base with the four plastic retention pieces on the washer plate.
      • Lower the agitator onto the tabs until it sits flush on the plate.
      FixBot'a Sor
      Yorum Ekle
      • Twist the agitator clockwise until it snaps and will not rotate freely.
      • Rock the agitator back and forth to confirm it is fully seated.
      FixBot'a Sor
      Yorum Ekle
      • Press the fabric-softener dispenser cap back onto the agitator top.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Repair didn't go as planned? Ask our Answers community for help.
Ben Schlichter
7.128 İtibar
224 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 48
Son 30 gün: 243
Her zaman: 1,013
