Ana içeriğe geç
Giriş
This purpose of this guide is to provide clear instructions for replacing the plastic housing for a GM Key Fob. Replacing just the housing, instead of the entire Fob, can save the individual a significant amount of money in addition to reducing environmental and electrical waste.
Aletler
  1. Pry apart the key ring to remove it from the old housing.
    • Pry apart the key ring to remove it from the old housing.
  2. Once you have removed the key ring,  use it to open the housing by wedging it into the groove, as pictured. Once you have removed the key ring,  use it to open the housing by wedging it into the groove, as pictured. Once you have removed the key ring,  use it to open the housing by wedging it into the groove, as pictured.
    • Once you have removed the key ring, use it to open the housing by wedging it into the groove, as pictured.
  3. Remove the electrical board and rubber key pad from the old housing. Remove the electrical board and rubber key pad from the old housing.
    • Remove the electrical board and rubber key pad from the old housing.
  4. Remove the electrical board from the rubber key pad. Remove the electrical board from the rubber key pad.
    • Remove the electrical board from the rubber key pad.
  5. If necessary, remove the battery from the electrical board and replace it. If necessary, remove the battery from the electrical board and replace it.
    • If necessary, remove the battery from the electrical board and replace it.
  6. After Opening the new Key Fob package, select the correct housing  as more than one model is included.
    • After Opening the new Key Fob package, select the correct housing as more than one model is included.
Sonuç
To reassemble your device, simply follow these disassembly instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
Megan Hayden
136 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 8
Son 30 Gün: 42
Her zaman: 748
