Ana içeriğe geç
GMMK-BRN Keyboard Switch Replacement
Neye ihtiyacın var
  1. GMMK-BRN Keyboard Switch Replacement, Keyboard Switch: adım 1, 2 resimden 1. GMMK-BRN Keyboard Switch Replacement, Keyboard Switch: adım 1, 2 resimden 2.
    • Unplug the keyboard from your device.
    • Place the keyboard on a clean workspace, along with the tools required.
  2. GMMK-BRN Keyboard Switch Replacement: adım 2, 3 resimden 1. GMMK-BRN Keyboard Switch Replacement: adım 2, 3 resimden 2. GMMK-BRN Keyboard Switch Replacement: adım 2, 3 resimden 3.
    • Use your fingers or a keycap remover and pull directly upward to remove the keycap.
    • It is possible to damage the keycap if not pulled directly upwards.
  3. GMMK-BRN Keyboard Switch Replacement: adım 3, 2 resimden 1. GMMK-BRN Keyboard Switch Replacement: adım 3, 2 resimden 2.
    • Use the switch remover to push the tabs in on the opposite sides of the switch.
    • Firmly pull the switch upwards.
    • If the switch is pulled at an angle, there is a risk to damaging the switch.
    • The switch may not come out easily, so more force may be required.
  4. GMMK-BRN Keyboard Switch Replacement: adım 4, 3 resimden 1. GMMK-BRN Keyboard Switch Replacement: adım 4, 3 resimden 2. GMMK-BRN Keyboard Switch Replacement: adım 4, 3 resimden 3.
    • Align the pins on the keycap with the ones inside the keyboard.
    • Insert the switch, and press down firmly until a click is heard.
  5. GMMK-BRN Keyboard Switch Replacement: adım 5, 3 resimden 1. GMMK-BRN Keyboard Switch Replacement: adım 5, 3 resimden 2. GMMK-BRN Keyboard Switch Replacement: adım 5, 3 resimden 3.
    • Align the cross of the keycap with the cross of the switch.
    • Push the keycap down firmly to reattach.
  6. GMMK-BRN Keyboard Switch Replacement: adım 6, 2 resimden 1. GMMK-BRN Keyboard Switch Replacement: adım 6, 2 resimden 2.
    • Plug the keyboard back into your device.
    • Turn you device on and do a test to see if the new switch works.
Sonuç
Kyle Lieu Dang
133 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 4
Son 30 gün: 38
Her zaman: 466
