Giriş
Brakes are some of the most important components on any sort of transportation device or vehicle, whether it's a bike, car, or scooter. Without brakes, coming to a full stop would be near impossible. For something like a scooter, needing to brake rapidly is extremely important as you have nothing to protect you. This guide will teach you how to successfully replace the brake caliper on your GOTRAX GMAX Ultra electric scooter. This scooter can go up to 30k/h so keeping your brakes in good working condition is necessary. Note that you will need a replacement brake caliper beforehand so contact the manufacturer for the required part prior to beginning the repair.
Neye ihtiyacın var
Use the 5mm hex key to remove the 16mm screw holding the brake cable in place.
To reassemble your device, simply follow these instructions in reverse order. You may have to adjust the caliper and brake cable in order for the disc to spin smoothly.
2 farklı kişi bu kılavuzu tamamladı.
