Ana içeriğe geç
GPD MicroPC
Neye ihtiyacın var
  1. GPD MicroPC, Prep: adım 1, 1 resimden 1.
    • Make sure device is fully powered off, remove any connected devices and micro SD cards.
    • Based on the nature of your need, backup any sensitive documents or files before starting.
    FixBot'a Sor
    Yorum Ekle
  2. GPD MicroPC: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    Phillips #00 Screwdriver
    $5.49
    • Remove 5 screws using a Phillips #00 Screwdriver
    • The opening for the screws is quite small, under 3mm. Ensure your tool has the clearance to fit.
    FixBot'a Sor
    Yorum Ekle
  3. GPD MicroPC: adım 3, 3 resimden 1. GPD MicroPC: adım 3, 3 resimden 2. GPD MicroPC: adım 3, 3 resimden 3.
    Spudger
    $3.99
    • Using a prying tool like a Spudger, pry open the bottom half.
    • There are some locking tabs on both the bottom half and the main body. There is a specific tab near the COM port which makes it tougher to pry open. It may be easier to pry from the LAN port area instead. Continue from that spot along the side towards the front audio jack and keep going until the bottom half easily comes off.
    • Remember to take out the MicroSD before continuing further
    FixBot'a Sor
    Yorum Ekle
  4. GPD MicroPC: adım 4, 2 resimden 1. GPD MicroPC: adım 4, 2 resimden 2.
    • The main components are now exposed.
    • The yellow boxes are where the locking tabs are located. The orange box highlights the COM specific tab mentioned earlier.
    • To reassemble, follow these instructions in reverse.
    • For an easier time during reassembly, line up the COM tab first and ensure that it is seated properly. If that tab isn't seated right, the bottom half may not come together properly leading to potential damages.
    FixBot'a Sor
    Yorum Ekle
Bitiş Çizgisi
4 farklı kişi bu kılavuzu tamamladı.
Mike
274 İtibar
1 Kılavuz yazıldı
2Kılavuz Yorumları
Bonjour ,je pourrais avoir la référence de la batterie s'il vous plait merci Voici mon numéro 06 65 55 57 51
mbc - Yanıt Paylaş
Information from OEM rechargeable Li-polymer battery label:
Model: 4841105-2S
Voltage: 7.6V
3100mAh 23.56Wh 2ICP5/41/105
Charge voltage:8.7V
"+" PIN1, PIN8 ; "-" PIN4, PIN5
Standard: GB31241-2014
Mfr: DONGGUAN GANFENG ELECTRONIC CO .,LTD
Apprx Size: 11cm x 4cm x 5mm*2 (there are two batteries stacked on top of each other)
Mike - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 82
Her zaman: 3,236
