Ana içeriğe geç
GPD WIN Silicon Pad Replacement
Neye ihtiyacın var
  1. GPD WIN Silicon Pad Replacement, Remove the screw of the case: adım 1, 2 resimden 1. GPD WIN Silicon Pad Replacement, Remove the screw of the case: adım 1, 2 resimden 2.
    • Remove the case screws
  2. GPD WIN Silicon Pad Replacement, Remove case: adım 2, 3 resimden 1. GPD WIN Silicon Pad Replacement, Remove case: adım 2, 3 resimden 2. GPD WIN Silicon Pad Replacement, Remove case: adım 2, 3 resimden 3.
    • There is a small space beside the keyboard, insert the pick and remove the claw
    • As you open the device, you can see that the flexible cable and the battery cable are connected. Then unplug the connector.
  3. GPD WIN Silicon Pad Replacement, Remove screws on the logic board: adım 3, 2 resimden 1. GPD WIN Silicon Pad Replacement, Remove screws on the logic board: adım 3, 2 resimden 2.
    • Remove screws on the logic board.
    • Because some black threads are mixed, do not forget to remove
  4. GPD WIN Silicon Pad Replacement, Remove the wifi connector on the logic board: adım 4, 2 resimden 1. GPD WIN Silicon Pad Replacement, Remove the wifi connector on the logic board: adım 4, 2 resimden 2.
    • Remove Wi-Fi antenna cable and LCD connector
  5. GPD WIN Silicon Pad Replacement, Remove the joystick: adım 5, 2 resimden 1. GPD WIN Silicon Pad Replacement, Remove the joystick: adım 5, 2 resimden 2.
    • Remove the screws of the joystick and remove the flex cable from the connector.
    • Then, it is ready to pull logic board out of the case.
  6. GPD WIN Silicon Pad Replacement, Replace the silicone pad: adım 6, 2 resimden 1. GPD WIN Silicon Pad Replacement, Replace the silicone pad: adım 6, 2 resimden 2.
    • You can access the silicone pad by removing the logic board.
    • Replace a sticky silicon pad
Sonuç
To reassemble your device, please follow these steps in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
jp en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
noria901
509 İtibar
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 34
Her zaman: 2,985
