Ana içeriğe geç
GPD Win Battery Replacement
Neye ihtiyacın var
  1. GPD Win Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Shut down your GPD Win.
  2. GPD Win Battery Replacement: adım 2, 1 resimden 1.
    • Remove SD card and duct cover.
  3. GPD Win Battery Replacement: adım 3, 1 resimden 1.
    • Remove the six PH #00 screws on the back of the GPD.
  4. GPD Win Battery Replacement: adım 4, 3 resimden 1. GPD Win Battery Replacement: adım 4, 3 resimden 2. GPD Win Battery Replacement: adım 4, 3 resimden 3.
    • Carefully insert the pry tool between the keyboard and case.
    • Move the tool around the edge until every clip is released.
    • Carefully lift the back half of the case.
    • You'll see a small ribbon connector on the right. Use your pry tool to remove it by lifting up.
    • On the right, you'll see another white connector going to the battery. Use the pry tool and pull back on the connector to release it.
  5. GPD Win Battery Replacement: adım 5, 3 resimden 1. GPD Win Battery Replacement: adım 5, 3 resimden 2. GPD Win Battery Replacement: adım 5, 3 resimden 3.
    • Separate the two halves of the device.
    • Use the pry tool and slowly and carefully separate the adhesive from the back of the case.
    • Remove old battery.
  6. GPD Win Battery Replacement: adım 6, 2 resimden 1. GPD Win Battery Replacement: adım 6, 2 resimden 2.
    • Use two to three strips of the double sided tape and apply it to the back of the battery.
    • Line up the battery with the lines on the case and the connector on the right.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
At the moment, the Shenzhen Zero Five Battery Company replacement comes with two wires crossed. You'll need a small metal pick to pry the clips open enough to pull the conductors out and swap them over. It should be red, yellow, black. I've performed the modification and can confirm it works after switching the contacts.
Dr. Nick - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 25
Son 30 gün: 97
Her zaman: 5,071
