Ana içeriğe geç
GPU Replacement
Neye ihtiyacın var
  1. GPU Replacement, Graphics Processing Unit: adım 1, 1 resimden 1.
    • Establish a clean work space.
  2. GPU Replacement: adım 2, 3 resimden 1. GPU Replacement: adım 2, 3 resimden 2. GPU Replacement: adım 2, 3 resimden 3.
    • Turn the desktop's power supply off.
    • Unplug the desktop from all power sources.
  3. GPU Replacement: adım 3, 2 resimden 1. GPU Replacement: adım 3, 2 resimden 2.
    • Remove the screws on the side of the case.
    • Screw types may vary by desktop case.
    • These screws hold the side panel, which promotes airflow inside the desktop. Do not misplace them.
  4. GPU Replacement: adım 4, 2 resimden 1. GPU Replacement: adım 4, 2 resimden 2.
    • Gently remove the side panel by pulling it away from the case.
  5. GPU Replacement: adım 5, 1 resimden 1.
    • Place the desktop horizontally, so the motherboard is facing up.
  6. GPU Replacement: adım 6, 3 resimden 1. GPU Replacement: adım 6, 3 resimden 2. GPU Replacement: adım 6, 3 resimden 3.
    • Disconnect the 8-pin PCI-E cable from the GPU.
  7. GPU Replacement: adım 7, 2 resimden 1. GPU Replacement: adım 7, 2 resimden 2.
    • Remove the UTS 6-32 screws on the side of the desktop using a Phillips #0 or a flathead screwdriver.
    • These screws hold the GPU in place. Do not misplace them.
  8. GPU Replacement: adım 8, 2 resimden 1. GPU Replacement: adım 8, 2 resimden 2.
    • Gently press down on the right side of the PCI-E tab until there is a click.
    • The click signifies the GPU has been released.
  9. GPU Replacement: adım 9, 1 resimden 1.
    • Gently pull the GPU out of the PCI-E slot.
  10. GPU Replacement: adım 10, 3 resimden 1. GPU Replacement: adım 10, 3 resimden 2. GPU Replacement: adım 10, 3 resimden 3.
    • Line up the pins of the new GPU with the empty PCI-E slot.
    • Gently push the new GPU into the PCI-E slot until the tab clicks.
  11. GPU Replacement: adım 11, 3 resimden 1. GPU Replacement: adım 11, 3 resimden 2. GPU Replacement: adım 11, 3 resimden 3.
    • Gently connect the 8-pin PCI-E cable from the power supply to the new GPU.
  12. GPU Replacement: adım 12, 2 resimden 1. GPU Replacement: adım 12, 2 resimden 2.
    • Screw the UTS 6-32 screws which hold the GPU in place back in using a Phillips #0 screwdriver.
  13. GPU Replacement: adım 13, 1 resimden 1.
    • Gently place the side panel back on the case.
  14. GPU Replacement: adım 14, 3 resimden 1. GPU Replacement: adım 14, 3 resimden 2. GPU Replacement: adım 14, 3 resimden 3.
    • Screw in the side panel screws.
  15. GPU Replacement: adım 15, 3 resimden 1. GPU Replacement: adım 15, 3 resimden 2. GPU Replacement: adım 15, 3 resimden 3.
    • Plug the desktop back into a power source.
    • Turn the desktop's power supply on.
    • If the fans on the bottom of the GPU are not spinning once the desktop is on, retry this process. Or begin troubleshooting for a defective GPU.
Bitiş Çizgisi
3 farklı kişi bu kılavuzu tamamladı.
Mason Price
319 İtibar
1 Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 2-16, Briggs Fall 2022 CSU Los Angeles, Team 2-16, Briggs Fall 2022 üyesi
CSULA-BRIGGS-F22S2G16
1 Üye
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 16
Son 30 gün: 77
Her zaman: 2,367
