Ana içeriğe geç
GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair
Neye ihtiyacın var
  1. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair, GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: adım 1, 2 resimden 1. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair, GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: adım 1, 2 resimden 2.
    • Take out the front metal grill.
    • By the side of the cover, there's a metal piece you have to flick open to get the front and back unlocked from each other.
  2. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: adım 2, 2 resimden 1. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: adım 2, 2 resimden 2.
    • Turn the knob to take out the blade cap.
    • Spin the knob counterclockwise. This way, you are loosening the knob.
  3. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: adım 3, 2 resimden 1. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: adım 3, 2 resimden 2.
    • Loosen the plastic nut on the rear grille in order to take the rear grille out.
  4. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: adım 4, 2 resimden 1. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: adım 4, 2 resimden 2.
    • Unscrew the plastic on the fan motor, and gently pull the slide open: There are four screws, proceed to taking off the plastic plates.
  5. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: adım 5, 2 resimden 1. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: adım 5, 2 resimden 2.
    • Apply machine oil onto the rusted parts.
    • Take the machine oil and make sure you apply the oil to the around fan rotor
    • Let the oil stay for about 5 minutes
    • Do not spill the oil on the surface or let the oil go into the rotor.
  6. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: adım 6, 2 resimden 1. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: adım 6, 2 resimden 2.
    • Carefully place the plastic plate properly on the surface of the fan rotor.
    • Make sure the screws align with the holes on the fan motor, then proceed to screw.
  7. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: adım 7, 1 resimden 1.
    • Place back the fan rear grill, pick up the plastic grill nut.
    • fit in the hole and screw down the fan rear grill upon the fan motor.
  8. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: adım 8, 1 resimden 1.
    • Place the blade right back into the motor pin.
    • Take the blade, make sure the blade sit on the fan edges.
  9. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: adım 9, 1 resimden 1.
    • Take the circlip, spin the circlip right on the blade, ensure it is tight.
  10. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: adım 10, 1 resimden 1.
    • Pick up the front grille, ensure the grille aligns with the metal piece around the fan.
    • Then lock the metal piece, this way the front and the rear grilles are locked.
    • If the metal piece do not align, you would have issues locking the grilles to each other.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
TUOYO FABIYI
238 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 11
Son 30 gün: 70
Her zaman: 482
