Ana içeriğe geç
Gaggia Classic Steam Valve replacement
Neye ihtiyacın var
  1. Gaggia Classic Steam Valve replacement, The Tools You Will Need: adım 1, 2 resimden 1. Gaggia Classic Steam Valve replacement, The Tools You Will Need: adım 1, 2 resimden 2.
    • Phillips screwdriver
    • Flathead screwdriver
    • 5mm T Allen wrench
    • Plier wrench
    • 18mm open wrench
    FixBot'a Sor
    Yorum Ekle
  2. Gaggia Classic Steam Valve replacement, Remove The Top Of The Machine: adım 2, 3 resimden 1. Gaggia Classic Steam Valve replacement, Remove The Top Of The Machine: adım 2, 3 resimden 2. Gaggia Classic Steam Valve replacement, Remove The Top Of The Machine: adım 2, 3 resimden 3.
    • Use the philips screwdriver to open the two screws on the top of the machine.
    • Lift the top cover and put it on the side.
    • Look inside and you will see the brass valve that attached to the steam knob(black arrow), the 2 allen screws (green arrows) and the copper (or stainless steel) steam wand pipe(red arrow).
    FixBot'a Sor
    Yorum Ekle
  3. Gaggia Classic Steam Valve replacement, Remove The Steam Knob: adım 3, 2 resimden 1. Gaggia Classic Steam Valve replacement, Remove The Steam Knob: adım 3, 2 resimden 2.
    • Pull the steam knob out. If its too hard, try to gently pry it out with a flathead screwdriver from the inner side of the machine.
    • Please be careful not to damage the plastic steam knob. Sometimes it can be fragile.
    FixBot'a Sor
    Yorum Ekle
  4. Gaggia Classic Steam Valve replacement, Remove Attachments From Steam Valve: adım 4, 3 resimden 1. Gaggia Classic Steam Valve replacement, Remove Attachments From Steam Valve: adım 4, 3 resimden 2. Gaggia Classic Steam Valve replacement, Remove Attachments From Steam Valve: adım 4, 3 resimden 3.
    • Use The 18mm wrench to open the hex nut.
    • Pull the copper pipe to the side so it wont be in the way.
    FixBot'a Sor
    Yorum Ekle
  5. Gaggia Classic Steam Valve replacement, Removing The Valve: adım 5, 3 resimden 1. Gaggia Classic Steam Valve replacement, Removing The Valve: adım 5, 3 resimden 2. Gaggia Classic Steam Valve replacement, Removing The Valve: adım 5, 3 resimden 3.
    • Use your allen wrench to open both screws for the steam valve.
    • Please pay attention: if the screws are too tight / rusted, if you try too hard they might break.
    • Move the steam valve from side to side and see if it comes off easily. If it seems to be stuck, use the pliers to move it sideways and up until it comes off.
    • Be carful not to damage the aluminum boiler.
    FixBot'a Sor
    Yorum Ekle
  6. Gaggia Classic Steam Valve replacement, Removing The Valve: adım 6, 3 resimden 1. Gaggia Classic Steam Valve replacement, Removing The Valve: adım 6, 3 resimden 2. Gaggia Classic Steam Valve replacement, Removing The Valve: adım 6, 3 resimden 3.
    • Remove the valve, gasket and the attached plastic piece and put it aside.
    • This is how an old steam valve looks.
    FixBot'a Sor
    Yorum Ekle
  7. Gaggia Classic Steam Valve replacement, Cleaning The Surface: adım 7, 3 resimden 1. Gaggia Classic Steam Valve replacement, Cleaning The Surface: adım 7, 3 resimden 2. Gaggia Classic Steam Valve replacement, Cleaning The Surface: adım 7, 3 resimden 3.
    • Now its time to clean the old gasket marks from the boiler
    • Use a wire brush to do the job
    • Please make sure the top of the boiler is clear from any objects (screws) that might fall into the open hole.
    FixBot'a Sor
    Yorum Ekle
  8. Gaggia Classic Steam Valve replacement, Prepearing The New Valve: adım 8, 3 resimden 1. Gaggia Classic Steam Valve replacement, Prepearing The New Valve: adım 8, 3 resimden 2. Gaggia Classic Steam Valve replacement, Prepearing The New Valve: adım 8, 3 resimden 3.
    • In the Kit you will find the new stainless steel valve with a black gasket and a small bag with food grade lube.
    • Lets get the valve ready to be installed! First, use the lube from the bag on the gasket and make sure its clean.
    • Second, place the plastic guard on the end of the valve with the flat side facing out.
    FixBot'a Sor
    Yorum Ekle
  9. Gaggia Classic Steam Valve replacement, Installing The Valve: adım 9, 3 resimden 1. Gaggia Classic Steam Valve replacement, Installing The Valve: adım 9, 3 resimden 2. Gaggia Classic Steam Valve replacement, Installing The Valve: adım 9, 3 resimden 3.
    • Place the new valve back on the boiler with the gasket facing down.
    • Insert both allen screws and lock them tight.
    • Install the copper steam line back on the valve. Use the 18mm open wrench to complete the job.
    FixBot'a Sor
    Yorum Ekle
  10. Gaggia Classic Steam Valve replacement, Finishing Up: adım 10, 3 resimden 1. Gaggia Classic Steam Valve replacement, Finishing Up: adım 10, 3 resimden 2. Gaggia Classic Steam Valve replacement, Finishing Up: adım 10, 3 resimden 3.
    • Install the steam knob back on the valve.
    • Put the top cover bak onto the machine and fasten both of the philips screws.
    • Congratulations! You are done!
    FixBot'a Sor
    Yorum Ekle
Bitiş Çizgisi
9 farklı kişi bu kılavuzu tamamladı.
iRobot
1 İtibar
636 adet Kılavuz yazıldı
5Kılavuz Yorumları
Done successfully. Note that it is not an 18mm nut for the steam connection. The correct size is 17mm. If you look closely in the picture, the 18mm wrench is fairly loose on the nut.
tresaudio - Yanıt Paylaş
It is a 17mm nut, correct
User - Yanıt Paylaş
I’m having trouble getting the valve to come out. It’s really stuck ! We’ve used a lot of pressure and it’s not even wiggly .
Leah Tollison - Yanıt Paylaş
The valve screws are no problem and do not break, but the valve itself is usually stuck in its "hole in the boiler".
Remove knob as described and use the 17mm open wrench to put on top the valve end after plastic guard towards the boiler.
Then use another heavy wrench (e.g. 19mm) or hammer to hammer the the valve from left to right and back from right to left.
This takes time and makes a loud noise, do not hammer on the valve direct, use the 17mm wrench to transport the force only from side to side.
Once the valve is moving put a screwdriver (or something similar) unter the valve between the boiler to ramp up the valve slowly (1mm per left-right-left turn is enough). Take your time, in about 10min you see the valve getting loose more and more and at the end you can lift it up.
User - Yanıt Paylaş
my challenge is that the stam knob is not reattaching easily. i have the metal on the round part when i push. It stays on but a big gap to the chassis, and falls off easily. Any ideas?
ajay gupta - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 30
Son 30 gün: 196
Her zaman: 16,148
