Ana içeriğe geç
Galaxy Tab S 10.5 Camera Replacement
Neye ihtiyacın var
    1. Galaxy Tab S 10.5 Camera Replacement, Back Cover: adım 1, 2 resimden 1. Galaxy Tab S 10.5 Camera Replacement, Back Cover: adım 1, 2 resimden 2.
      • Place the plastic opening tool into the SD card slot or charge port.
      • Try in an upward motion until you see a separation between the tablet and back cover.
      FixBot'a Sor
      Yorum Ekle
    2. Galaxy Tab S 10.5 Camera Replacement: adım 2, 1 resimden 1.
      • Work around the entire device by sliding the plastic opening tool around the rim.
      • If this is the first time, it will be hard to separate the back cover from the tablet.
      • The clips are approximately 5 cm apart. While working around the device, the clips will make a dislocating sound when disconnected.
      FixBot'a Sor
      Yorum Ekle
    3. Galaxy Tab S 10.5 Camera Replacement: adım 3, 1 resimden 1.
      • Remove the back cover once all links have been separated.
      • Be careful when touching any of the internal components of the tablet.
      FixBot'a Sor
      Yorum Ekle
    1. Galaxy Tab S 10.5 Camera Replacement, Camera: adım 4, 3 resimden 1. Galaxy Tab S 10.5 Camera Replacement, Camera: adım 4, 3 resimden 2. Galaxy Tab S 10.5 Camera Replacement, Camera: adım 4, 3 resimden 3.
      • Use a spudger to disconnect the camera from the motherboard and then remove the camera.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jordan Soto
3.318 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-2, Eyestone Fall 2015 USF Tampa, Team 3-2, Eyestone Fall 2015 üyesi
USFT-EYESTONE-F15S3G2
3 Üyeler
20 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 64
Her zaman: 3,066
