Ana içeriğe geç
Galaxy Watch Active2 Core Assembly Removal
Neye ihtiyacın var
  1. Galaxy Watch Active2 Core Assembly Removal, Turn off the watch: adım 1, 2 resimden 1. Galaxy Watch Active2 Core Assembly Removal, Turn off the watch: adım 1, 2 resimden 2.
    • Turn off the Galaxy Watch Active2 by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
    • When the "Power off" symbol appears, tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
  2. Galaxy Watch Active2 Core Assembly Removal, Remove the rear screws: adım 2, 1 resimden 1.
    • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
  3. Galaxy Watch Active2 Core Assembly Removal, Separate the back cover from the housing: adım 3, 3 resimden 1. Galaxy Watch Active2 Core Assembly Removal, Separate the back cover from the housing: adım 3, 3 resimden 2. Galaxy Watch Active2 Core Assembly Removal, Separate the back cover from the housing: adım 3, 3 resimden 3.
    • Use an opening pick and place it between the plastic back cover and the metal housing near the buttons.
    • Push the opening pick into the gap to separate the back cover from the housing.
    • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
  4. Galaxy Watch Active2 Core Assembly Removal, Disconnect the sensor array: adım 4, 2 resimden 1. Galaxy Watch Active2 Core Assembly Removal, Disconnect the sensor array: adım 4, 2 resimden 2.
    • Carefully lift the back cover to access the sensor array connector.
    • Use a spudger to disconnect the sensor array from the motherboard.
  5. Galaxy Watch Active2 Core Assembly Removal, Remove the back cover: adım 5, 1 resimden 1.
    • Remove the back cover.
  6. Galaxy Watch Active2 Core Assembly Removal, Disconnect the display and speaker: adım 6, 3 resimden 1. Galaxy Watch Active2 Core Assembly Removal, Disconnect the display and speaker: adım 6, 3 resimden 2. Galaxy Watch Active2 Core Assembly Removal, Disconnect the display and speaker: adım 6, 3 resimden 3.
    • Use a spudger to disconnect the display assembly and the speaker.
  7. Galaxy Watch Active2 Core Assembly Removal, Disconnect the barometric sensor, buttons, and mic: adım 7, 3 resimden 1. Galaxy Watch Active2 Core Assembly Removal, Disconnect the barometric sensor, buttons, and mic: adım 7, 3 resimden 2. Galaxy Watch Active2 Core Assembly Removal, Disconnect the barometric sensor, buttons, and mic: adım 7, 3 resimden 3.
    • Use a spudger to disconnect the barometric sensor, the buttons, and the microphone.
  8. Galaxy Watch Active2 Core Assembly Removal, Lift the core assembly: adım 8, 2 resimden 1. Galaxy Watch Active2 Core Assembly Removal, Lift the core assembly: adım 8, 2 resimden 2.
    • Place a spudger underneath the motherboard at the top right next to the display connector.
    • Slightly twist and lever the spudger to loosen the core assembly.
    • It might help to also check the comments below this and the next step if you’re having difficulties.
  9. Galaxy Watch Active2 Core Assembly Removal, Remove the core assembly: adım 9, 3 resimden 1. Galaxy Watch Active2 Core Assembly Removal, Remove the core assembly: adım 9, 3 resimden 2. Galaxy Watch Active2 Core Assembly Removal, Remove the core assembly: adım 9, 3 resimden 3.
    • Grab the core assembly and carefully slide it out from under the cables.
    • Remove the core assembly.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Tobias Isakeit
124.396 İtibar
189 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 17
Son 30 gün: 91
Her zaman: 8,311
