Giriş
Use this guide to remove the buttons in your Game Boy Advance
Aletler
Parçalar
Hiçbir parça belirtilmedi.
Take the battery cover off by releasing the locking tab and hinging the cover away.
Remove bottom back panel screw with a Phillips #1 screw driver.
We recommend you change the the screw head to a Phillips 1 so you don't strip the screw. (Something we experienced)
Remove left and right triggers by lifting and pulling them away from the system.
Do the same for side panels
Remove the gray On/Off Switch by pulling up and away from the unit. Replace with another switch if necessary.
Remove the three screws on the circuit board with a Phillips #1 screw driver.
Remove the rubber button pads from their pockets.
Remove the plastic buttons and the D-pad from beneath the rubber pads with tweezers or by hand.
7 farklı kişi bu kılavuzu tamamladı.
