Giriş
Use this repair guide in order to replace the speakers.
Neye ihtiyacın var
Take the battery cover off by releasing the locking tab and hinging the cover away. Remove the batteries inside the cover
Remove the six back panel screws using a Tri-wing Screwdriver.
Remove bottom back panel screw with a Phillips #1 screw driver. (Image #2)
Remove the back panel by pulling away with one hand and the front secured in the other hand.
Remove left and right triggers by lifting and pulling them away from the system.
Do the same for side panels
Remove the gray On/Off Switch by pulling up and away from the unit. Replace with another switch if necessary.
Bu adımda kullanılan alet:Tweezers$4.99
Remove the rubber button pads from their pockets.
Remove the plastic buttons and the D-pad from beneath the rubber pads with tweezers or by hand.
Using the tweezers, gently pull the ribbon from the logic board.
9 farklı kişi bu kılavuzu tamamladı.
2 Yorum
When no sound in GBA. Is the broken speaker the most common problem ? Or some SMD part in circuit board ? What to do if the new replaced speaker emits no sound ?
I'm just going to say it. this guide kind of sucks fr. What am I supposed to do after the desolder? Why do I need the desoldering braid? Like you end it with step 8 "Slightly move the speaker to the right and desolder the two wires from the logic board." What temp should my iron be??
