Ana içeriğe geç
Game Boy Advance Speakers Replacement
Neye ihtiyacın var
  1. Game Boy Advance Speakers Replacement, Remove the Battery Cover/Batteries: adım 1, 3 resimden 1. Game Boy Advance Speakers Replacement, Remove the Battery Cover/Batteries: adım 1, 3 resimden 2. Game Boy Advance Speakers Replacement, Remove the Battery Cover/Batteries: adım 1, 3 resimden 3.
    • Take the battery cover off by releasing the locking tab and hinging the cover away. Remove the batteries inside the cover
    • Do not forget to remove the batteries! This applies to working with any electronic device as working with live electricity may damage the device or cause malfunctions
  2. Game Boy Advance Speakers Replacement, Unscrew the Back Panel: adım 2, 2 resimden 1. Game Boy Advance Speakers Replacement, Unscrew the Back Panel: adım 2, 2 resimden 2.
    • Remove the six back panel screws using a Tri-wing Screwdriver.
    • Remove bottom back panel screw with a Phillips #1 screw driver. (Image #2)
  3. Game Boy Advance Speakers Replacement, Remove the Back Panel: adım 3, 1 resimden 1.
    • Remove the back panel by pulling away with one hand and the front secured in the other hand.
    • Removal of the back panel may cause shoulder buttons and side panels to come loose and fall off.
  4. Game Boy Advance Speakers Replacement, Remove Triggers: adım 4, 2 resimden 1. Game Boy Advance Speakers Replacement, Remove Triggers: adım 4, 2 resimden 2.
    • Remove left and right triggers by lifting and pulling them away from the system.
    • Do the same for side panels
    • For finicky or jammed triggers only! Adjust and correct triggers and reassemble. Most jammed triggers are caused by buttons misplaced or jammed in its enclosure.
    my side pannel on the right is a little loose how do i fix it
    Mark - Yanıt
  5. Game Boy Advance Speakers Replacement, Remove the On/Off Switch: adım 5, 1 resimden 1.
    • Remove the gray On/Off Switch by pulling up and away from the unit. Replace with another switch if necessary.
  6. Game Boy Advance Speakers Replacement, Buttons: adım 6, 3 resimden 1. Game Boy Advance Speakers Replacement, Buttons: adım 6, 3 resimden 2. Game Boy Advance Speakers Replacement, Buttons: adım 6, 3 resimden 3.
    • Remove the rubber button pads from their pockets.
    • Remove the plastic buttons and the D-pad from beneath the rubber pads with tweezers or by hand.
  7. Game Boy Advance Speakers Replacement, Speakers: adım 7, 3 resimden 1. Game Boy Advance Speakers Replacement, Speakers: adım 7, 3 resimden 2. Game Boy Advance Speakers Replacement, Speakers: adım 7, 3 resimden 3.
    • Using the tweezers, gently pull the ribbon from the logic board.
    DO NOT USE TWEEZERS ON THE RIBBON CABLE. DO NOT PULL ON THE RIBBON CABLE LIKE THAT.
    theres 2 brown tabs on each side of the connector. You slide both those up and the ribbon cable slides right out with no need to use tweezers. Don't risk damaging your ribbon cable.
    Vincent C. - Yanıt
  8. Game Boy Advance Speakers Replacement: adım 8, 3 resimden 1. Game Boy Advance Speakers Replacement: adım 8, 3 resimden 2. Game Boy Advance Speakers Replacement: adım 8, 3 resimden 3.
    • Slightly move the speaker to the right and desolder the two wires from the logic board.
    • Beware of over heating the soldering kit will damage the logic board.
Bitiş Çizgisi
9 farklı kişi bu kılavuzu tamamladı.
Adam
815 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 16-29, Maness Winter 2010 Cal Poly, Team 16-29, Maness Winter 2010 üyesi
CPSU-MANESS-W10S16G29
5 Üyeler
61 adet Kılavuz yazıldı
Bir Yorum
When no sound in GBA. Is the broken speaker the most common problem ? Or some SMD part in circuit board ? What to do if the new replaced speaker emits no sound ?
Pekka Hollola - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 39
Son 30 gün: 129
Her zaman: 14,246
