Ana içeriğe geç
Game Boy Color Buttons Replacement
Neye ihtiyacın var
    1. Game Boy Color Buttons Replacement, Battery: adım 1, 2 resimden 1. Game Boy Color Buttons Replacement, Battery: adım 1, 2 resimden 2.
      • Locate the battery compartment on the back of the Game Boy Color.
      • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
      FixBot'a Sor
      Yorum Ekle
    2. Game Boy Color Buttons Replacement: adım 2, 1 resimden 1.
      • Remove the batteries from the battery compartment.
      FixBot'a Sor
      Yorum Ekle
    1. Game Boy Color Buttons Replacement, Back Housing: adım 3, 1 resimden 1.
      • Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
      FixBot'a Sor
      Yorum Ekle
    2. Game Boy Color Buttons Replacement: adım 4, 2 resimden 1. Game Boy Color Buttons Replacement: adım 4, 2 resimden 2.
      • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing out!
      FixBot'a Sor
      Yorum Ekle
    1. Game Boy Color Buttons Replacement, LCD Ribbon Cable: adım 5, 3 resimden 1. Game Boy Color Buttons Replacement, LCD Ribbon Cable: adım 5, 3 resimden 2. Game Boy Color Buttons Replacement, LCD Ribbon Cable: adım 5, 3 resimden 3.
      • Push up on the tabs on either side of the ribbon with a spudger.
      FixBot'a Sor
      Yorum Ekle
    2. Game Boy Color Buttons Replacement: adım 6, 2 resimden 1. Game Boy Color Buttons Replacement: adım 6, 2 resimden 2.
      • Gently remove the ribbon cable from the port
      FixBot'a Sor
      Yorum Ekle
    1. Game Boy Color Buttons Replacement, Motherboard: adım 7, 2 resimden 1. Game Boy Color Buttons Replacement, Motherboard: adım 7, 2 resimden 2.
      • Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture.
      FixBot'a Sor
      Yorum Ekle
    2. Game Boy Color Buttons Replacement: adım 8, 1 resimden 1.
      • Gently lift the motherboard from the front housing.
      FixBot'a Sor
      Yorum Ekle
    1. Game Boy Color Buttons Replacement, Buttons: adım 9, 1 resimden 1.
      • Remove the rubber backing on each button grouping.
      FixBot'a Sor
      Yorum Ekle
    2. Game Boy Color Buttons Replacement: adım 10, 1 resimden 1.
      • Remove the original buttons from the housing.
      FixBot'a Sor
      Yorum Ekle
Sonuç
29 farklı kişi bu kılavuzu tamamladı.
Nick Katsantones
1.166 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 19-47, Regan Winter 2013 Cal Poly, Team 19-47, Regan Winter 2013 üyesi
CPSU-REGAN-W13S19G47
4 Üyeler
70 adet Kılavuz yazıldı
3Kılavuz Yorumları
Thank you for your information on repair of my color game boy.
just two things.
1. I had a hard time with the removal of the screws. Any tip on that would be helpful.
2. Where can I purchase replacement parts?
Thanks again for all of your help.
Ray Blasko
raymondblasko - Yanıt Paylaş
In the tools needed it states Y0 screwdriver, but in step 3 it says Y1 which is not the same. Which one is the correct size?
blogcraft - Yanıt Paylaş
I found either Y0 or Y1 works. The important thing is it's a small tri-wing.
Michael Schwern - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 64
Son 30 gün: 235
Her zaman: 35,097
