Ana içeriğe geç
Game Boy Color Front Housing Replacement
Neye ihtiyacın var
  1. Game Boy Color Front Housing Replacement, Battery: adım 1, 2 resimden 1. Game Boy Color Front Housing Replacement, Battery: adım 1, 2 resimden 2.
    • Locate the battery compartment on the back of the Game Boy Color.
    • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
  2. Game Boy Color Front Housing Replacement: adım 2, 1 resimden 1.
    • Remove the batteries from the battery compartment.
  3. Game Boy Color Front Housing Replacement, Back Housing: adım 3, 1 resimden 1.
    • Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
  4. Game Boy Color Front Housing Replacement: adım 4, 2 resimden 1. Game Boy Color Front Housing Replacement: adım 4, 2 resimden 2.
    • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing out!
  5. Game Boy Color Front Housing Replacement, LCD Ribbon Cable: adım 5, 3 resimden 1. Game Boy Color Front Housing Replacement, LCD Ribbon Cable: adım 5, 3 resimden 2. Game Boy Color Front Housing Replacement, LCD Ribbon Cable: adım 5, 3 resimden 3.
    • Push up on the tabs on either side of the ribbon with a spudger.
  6. Game Boy Color Front Housing Replacement: adım 6, 2 resimden 1. Game Boy Color Front Housing Replacement: adım 6, 2 resimden 2.
    • Gently remove the ribbon cable from the port
  7. Game Boy Color Front Housing Replacement, Motherboard: adım 7, 2 resimden 1. Game Boy Color Front Housing Replacement, Motherboard: adım 7, 2 resimden 2.
    • Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture.
  8. Game Boy Color Front Housing Replacement: adım 8, 1 resimden 1.
    • Gently lift the motherboard from the front housing.
  9. Game Boy Color Front Housing Replacement, Buttons: adım 9, 1 resimden 1.
    • Remove the rubber backing on each button grouping.
  10. Game Boy Color Front Housing Replacement: adım 10, 1 resimden 1.
    • Remove the original buttons from the housing.
  11. Game Boy Color Front Housing Replacement, LCD Display: adım 11, 2 resimden 1. Game Boy Color Front Housing Replacement, LCD Display: adım 11, 2 resimden 2.
    • Gently pry and lift the LCD Display from the front panel.
    • Twisting the front casing may help gain more leverage.
Sonuç
20 farklı kişi bu kılavuzu tamamladı.
Angela Yoeurng
1.809 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 19-47, Regan Winter 2013 Cal Poly, Team 19-47, Regan Winter 2013 üyesi
CPSU-REGAN-W13S19G47
4 Üyeler
61 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 76
Her zaman: 12,048
