Ana içeriğe geç
Game Boy Color LCD Display Replacement
Neye ihtiyacın var
  1. Game Boy Color LCD Display Replacement, Battery: adım 1, 2 resimden 1. Game Boy Color LCD Display Replacement, Battery: adım 1, 2 resimden 2.
    • Locate the battery compartment on the back of the Game Boy Color.
    • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
    FixBot'a Sor
    Yorum Ekle
  2. Game Boy Color LCD Display Replacement: adım 2, 1 resimden 1.
    • Remove the batteries from the battery compartment.
    FixBot'a Sor
    Yorum Ekle
  3. Game Boy Color LCD Display Replacement, Back Housing: adım 3, 1 resimden 1.
    • Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
    FixBot'a Sor
    Yorum Ekle
  4. Game Boy Color LCD Display Replacement: adım 4, 2 resimden 1. Game Boy Color LCD Display Replacement: adım 4, 2 resimden 2.
    • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing out!
    FixBot'a Sor
    Yorum Ekle
  5. Game Boy Color LCD Display Replacement, LCD Ribbon Cable: adım 5, 3 resimden 1. Game Boy Color LCD Display Replacement, LCD Ribbon Cable: adım 5, 3 resimden 2. Game Boy Color LCD Display Replacement, LCD Ribbon Cable: adım 5, 3 resimden 3.
    • Push up on the tabs on either side of the ribbon with a spudger.
    FixBot'a Sor
    Yorum Ekle
  6. Game Boy Color LCD Display Replacement: adım 6, 2 resimden 1. Game Boy Color LCD Display Replacement: adım 6, 2 resimden 2.
    • Gently remove the ribbon cable from the port
    FixBot'a Sor
    Yorum Ekle
  7. Game Boy Color LCD Display Replacement, Motherboard: adım 7, 2 resimden 1. Game Boy Color LCD Display Replacement, Motherboard: adım 7, 2 resimden 2.
    • Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture.
    FixBot'a Sor
    Yorum Ekle
  8. Game Boy Color LCD Display Replacement: adım 8, 1 resimden 1.
    • Gently lift the motherboard from the front housing.
    FixBot'a Sor
    Yorum Ekle
  9. Game Boy Color LCD Display Replacement, LCD Display: adım 9, 2 resimden 1. Game Boy Color LCD Display Replacement, LCD Display: adım 9, 2 resimden 2.
    • Gently pry and lift the LCD Display from the front panel.
    • Twisting the front casing may help gain more leverage.
    FixBot'a Sor
    Yorum Ekle
Sonuç
47 farklı kişi bu kılavuzu tamamladı.
Ajmal Puyehgar
636 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 19-47, Regan Winter 2013 Cal Poly, Team 19-47, Regan Winter 2013 üyesi
CPSU-REGAN-W13S19G47
4 Üyeler
70 adet Kılavuz yazıldı
8Kılavuz Yorumları
I broke my screen doing this. Be really gentle!
Andrew - Yanıt Paylaş
Broke my screen just like the last commenter. These instructions are retarded. DON’T pry the screen from the back. Take the front cover off and PUSH it from the front. The circuity for the display is encased in the thin piece of glass all around the LCD. Prying WILL break it!
VoopTech - Yanıt Paylaş
Hi, how to remove the front safe screen? Do i need a sucker?
Thanks
SteR - Yanıt Paylaş
Horrible instructions, TBH.
Michelle Fernandez - Yanıt Paylaş
Broke the plastic around the screen and doesn't turn on anymore -_- . Guess now I can put a backlit in but not how I wanted it to go
Daniel Guerrero - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 110
Son 30 gün: 462
Her zaman: 66,403
