Ana içeriğe geç
Game Boy Color LCD Ribbon Cable Replacement
Neye ihtiyacın var
  1. Game Boy Color LCD Ribbon Cable Replacement, Battery: adım 1, 2 resimden 1. Game Boy Color LCD Ribbon Cable Replacement, Battery: adım 1, 2 resimden 2.
    • Locate the battery compartment on the back of the Game Boy Color.
    • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
  2. Game Boy Color LCD Ribbon Cable Replacement: adım 2, 1 resimden 1.
    • Remove the batteries from the battery compartment.
  3. Game Boy Color LCD Ribbon Cable Replacement, Back Housing: adım 3, 1 resimden 1.
    • Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
    I did this with a Y0 bit. It works if you are careful. I wouldn't recommend it on other consoles but for this tiny thing, it works.
    phnome - Yanıt
    The guide says a Y0 is needed. Is it a Y1 or Y0?
    Trav - Yanıt
  4. Game Boy Color LCD Ribbon Cable Replacement: adım 4, 2 resimden 1. Game Boy Color LCD Ribbon Cable Replacement: adım 4, 2 resimden 2.
    • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing out!
  5. Game Boy Color LCD Ribbon Cable Replacement, LCD Ribbon Cable: adım 5, 1 resimden 1.
    • Push up on the tabs on either side of the ribbon with a spudger.
  6. Game Boy Color LCD Ribbon Cable Replacement: adım 6, 1 resimden 1.
    • Gently remove the ribbon cable from the port
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Nick Katsantones
949 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 19-47, Regan Winter 2013 Cal Poly, Team 19-47, Regan Winter 2013 üyesi
CPSU-REGAN-W13S19G47
4 Üyeler
61 adet Kılavuz yazıldı
Bir Yorum
How many pins are in the ribbon?
jakebrown199 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 22
Son 30 gün: 94
Her zaman: 8,393
