Ana içeriğe geç
Game Boy Color Screen Cover Replacement
Neye ihtiyacın var
    1. Game Boy Color Screen Cover Replacement, Battery: adım 1, 2 resimden 1. Game Boy Color Screen Cover Replacement, Battery: adım 1, 2 resimden 2.
      • Locate the battery compartment on the back of the Game Boy Color.
      • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
      FixBot'a Sor
      Yorum Ekle
    2. Game Boy Color Screen Cover Replacement: adım 2, 1 resimden 1.
      • Remove the batteries from the battery compartment.
      FixBot'a Sor
      Yorum Ekle
    1. Game Boy Color Screen Cover Replacement, Screen Cover: adım 3, 1 resimden 1.
      • Carefully slide a razor blade under one of the corners of the screen cover.
      FixBot'a Sor
      Yorum Ekle
    2. Game Boy Color Screen Cover Replacement: adım 4, 1 resimden 1.
      • Carefully lift up on the corner of the screen until you can grab the corner with your fingers.
      • Continue gently pulling up on the cover until it is fully removed.
      FixBot'a Sor
      Yorum Ekle
Sonuç
27 farklı kişi bu kılavuzu tamamladı.
Nick Katsantones
1.169 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 19-47, Regan Winter 2013 Cal Poly, Team 19-47, Regan Winter 2013 üyesi
CPSU-REGAN-W13S19G47
4 Üyeler
108 adet Kılavuz yazıldı
4Kılavuz Yorumları
bro, you mustn't to dismount the console to only remove the old lend
sdfsafas - Yanıt Paylaş
You only need step 7 and 8.
h027299c - Yanıt Paylaş
An alternative method is to in step 7 insert a small screwdriver into the hole in the front shell where the power light goes through and push off the screen enough to pry it off with your hands. Thereby avoiding this razor-near-the-screen business. You will also most likely need some alcohol (or similar) to loosen the residue leftover from the old screen.
Nick G - Yanıt Paylaş
Yes that's true! I've seen repair videos where they do it the way you mentioned, much less of a headache
David Hannum - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 62
Son 30 gün: 215
Her zaman: 26,960
