Ana içeriğe geç
Game Boy Display Lines/Bars
Neye ihtiyacın var
  1. Game Boy Display Lines/Bars, Game Boy Display Lines/Bars: adım 1, 3 resimden 1. Game Boy Display Lines/Bars, Game Boy Display Lines/Bars: adım 1, 3 resimden 2. Game Boy Display Lines/Bars, Game Boy Display Lines/Bars: adım 1, 3 resimden 3.
    • Remove the back housing by removing the 6 Tri-Point or Philip screws.
    • Note: The last 2 screws are in the battery compartment.
  2. Game Boy Display Lines/Bars: adım 2, 2 resimden 1. Game Boy Display Lines/Bars: adım 2, 2 resimden 2.
    • Carefully lift up the top half of the system. Be careful, there's a ribbon cable that connects the top and bottom half of the system.
    • Remove the ribbon cable for the next step.
  3. Game Boy Display Lines/Bars: adım 3, 3 resimden 1. Game Boy Display Lines/Bars: adım 3, 3 resimden 2. Game Boy Display Lines/Bars: adım 3, 3 resimden 3.
    • Now there will be screws that mount the board to the front, carefully unscrew these.
    • Now remove the board from the housing.
    • Now put the batteries back into the compartment, so you can test the screen while you fix it.
    • Reconnect the the board to back housing with the ribbon cable.
  4. Game Boy Display Lines/Bars: adım 4, 1 resimden 1.
    • You're now going to turn the contrast ( the slider on the left) all the way up, and take your soldering iron and gently move it back and forth on the ribbon cable below the screen.
    • Make sure not to touch the screen itself.
    • Note: There may be a rubber strip covering the ribbon.
    • You will start to see the lines of pixels fade in and out, keep moving your iron back and forth until screen is completely black.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Mitchell
191 İtibar
1 Kılavuz yazıldı
2Kılavuz Yorumları
Hi, this is the second time I attempt this fix, the first time it worked perfectly. The problem is that with this second machine there's a couple of pixel lines that have not tickled back to black even though I have been patiently going over them for quite some time (2 rounds of 10-15 min) is there anything else that I could try or should I just go on over the same area until I see something happen? Thanks in advance
Jose Saura - Yanıt
Use this guide linked below understand where to place the iron under the screen. Step 4 doesn't seem to contain the proper images or details of this step here well enough.
https://www.youtube.com/watch?v=-OEXhxoT...
Bossman207 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 25
Son 30 gün: 149
Her zaman: 5,724
