Neye ihtiyacın var
Remove the Phillips #00 screw on the side of the Game Boy closest to the directional pad.
Once the screw has been loosened, lift the cover off the back of the device.
Grip, and gently pull outwards on the cable as close to the battery connector as you can
Near the volume button, unscrew the two side screws
Near the external port, unscrew the two side screws
Unscrew these two tri-point screws holding the backplate in place.
Start to lift out the backplate near the top-right corner, and then you can gently wiggle it up and off.
The faceplate is held on by two plastic clips near the battery screw.
Push in the holes with a bent paperclip or SIM eject tool with minor force.
Once both clips are undone, the faceplate lifts off like turning a page in a book backwards.
Lift the left side, and lift it upwards and right.
Then it should be possible to just lift it upwards to remove it.
Grab the frontplate like shown
Lift the frontplate up and away
Start to lift the top part upwards
While lifting, try to unhook the bottom catches to let you lift the frontplate away
Insert the short part of the Start/Select buttons in the middle first
Then lay the long part into its groove. It should just rest in there, do not press on it at all!
Bir başkası bu kılavuzu tamamladı.
