Ana içeriğe geç
Game Boy Pocket Buttons Replacement
Neye ihtiyacın var
  1. Game Boy Pocket Buttons Replacement, Buttons: adım 1, 3 resimden 1. Game Boy Pocket Buttons Replacement, Buttons: adım 1, 3 resimden 2. Game Boy Pocket Buttons Replacement, Buttons: adım 1, 3 resimden 3.
    • Place the Game Boy Pocket face-down on a clean, flat surface.
    • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the four external screws.
    • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the two screws inside the battery compartment.
  2. Game Boy Pocket Buttons Replacement: adım 2, 3 resimden 1. Game Boy Pocket Buttons Replacement: adım 2, 3 resimden 2. Game Boy Pocket Buttons Replacement: adım 2, 3 resimden 3.
    • Place your hands on the front and back covers of the Game Boy Pocket, and carefully separate the device.
    • Set the back cover aside. You will need it to reassemble the device.
  3. Game Boy Pocket Buttons Replacement: adım 3, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove the three screws from the motherboard.
  4. Game Boy Pocket Buttons Replacement: adım 4, 3 resimden 1. Game Boy Pocket Buttons Replacement: adım 4, 3 resimden 2. Game Boy Pocket Buttons Replacement: adım 4, 3 resimden 3.
    • Use a plastic opening tool to dislodge and remove the clip securing the ribbon cable.
    • Make sure you apply pressure on both sides of the clip to loosen it.
  5. Game Boy Pocket Buttons Replacement: adım 5, 2 resimden 1. Game Boy Pocket Buttons Replacement: adım 5, 2 resimden 2.
    • Use a plastic opening tool to dislodge the ribbon cable.
    • Be gentle to prevent tearing the ribbon.
  6. Game Boy Pocket Buttons Replacement: adım 6, 3 resimden 1. Game Boy Pocket Buttons Replacement: adım 6, 3 resimden 2. Game Boy Pocket Buttons Replacement: adım 6, 3 resimden 3.
    • Grab the black piece protruding from the motherboard, and lift up to remove the motherboard.
    • Set the motherboard aside. You will need it to reassemble the device.
  7. Game Boy Pocket Buttons Replacement: adım 7, 3 resimden 1. Game Boy Pocket Buttons Replacement: adım 7, 3 resimden 2. Game Boy Pocket Buttons Replacement: adım 7, 3 resimden 3.
    • Use your fingers to remove the three silicone button covers.
    • Use a plastic opening tool to remove the buttons.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Adriana Rahrig
1.637 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Leahy Fall 2014 USF Tampa, Team 1-1, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S1G1
4 Üyeler
19 adet Kılavuz yazıldı
1Rehber Yorum
where can you just buy the a and b buttons (if possible)
Eian Anderson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 62
Her zaman: 5,022
