Ana içeriğe geç
Game Boy Pocket LCD Screen Replacement
Neye ihtiyacın var
  1. Game Boy Pocket LCD Screen Replacement, Remove the external screws: adım 1, 3 resimden 1. Game Boy Pocket LCD Screen Replacement, Remove the external screws: adım 1, 3 resimden 2. Game Boy Pocket LCD Screen Replacement, Remove the external screws: adım 1, 3 resimden 3.
    • Place the Game Boy Pocket face-down on a clean, flat surface.
    • Remove batteries from battery compartment.
    • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the four external screws.
    • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the two screws inside the battery compartment.
    Where do I find a oem lcd replacement?
    Alex Bone - Yanıt
  2. Game Boy Pocket LCD Screen Replacement, Open the device: adım 2, 3 resimden 1. Game Boy Pocket LCD Screen Replacement, Open the device: adım 2, 3 resimden 2. Game Boy Pocket LCD Screen Replacement, Open the device: adım 2, 3 resimden 3.
    • Place your hands on the front and back covers of the Game Boy Pocket, and carefully separate the device.
    • Set the back cover aside. You will need it to reassemble the device.
  3. Game Boy Pocket LCD Screen Replacement, Remove the motherboard screws: adım 3, 1 resimden 1.
    • Use a Phillips #1 screwdriver and turn counterclockwise to remove the three screws on the motherboard.
  4. Game Boy Pocket LCD Screen Replacement, Remove the clip securing the ribbon cable: adım 4, 3 resimden 1. Game Boy Pocket LCD Screen Replacement, Remove the clip securing the ribbon cable: adım 4, 3 resimden 2. Game Boy Pocket LCD Screen Replacement, Remove the clip securing the ribbon cable: adım 4, 3 resimden 3.
    • Use a plastic opening tool to dislodge and remove the clip securing the ribbon cable.
    • Make sure you apply pressure on both sides of the clip to loosen it.
  5. Game Boy Pocket LCD Screen Replacement, Dislodge the ribbon cable: adım 5, 2 resimden 1. Game Boy Pocket LCD Screen Replacement, Dislodge the ribbon cable: adım 5, 2 resimden 2.
    • Use a plastic opening tool to dislodge the ribbon cable.
    • Be gentle to prevent tearing the ribbon.
  6. Game Boy Pocket LCD Screen Replacement, Remove the motherboard: adım 6, 3 resimden 1. Game Boy Pocket LCD Screen Replacement, Remove the motherboard: adım 6, 3 resimden 2. Game Boy Pocket LCD Screen Replacement, Remove the motherboard: adım 6, 3 resimden 3.
    • Grab the black piece protruding from the motherboard, and lift up to remove the motherboard.
    • Set the motherboard aside. You will need it to reassemble the device.
  7. Game Boy Pocket LCD Screen Replacement, Remove the LCD screen: adım 7, 3 resimden 1. Game Boy Pocket LCD Screen Replacement, Remove the LCD screen: adım 7, 3 resimden 2. Game Boy Pocket LCD Screen Replacement, Remove the LCD screen: adım 7, 3 resimden 3.
    • Use a plastic opening tool to lift the LCD screen away from the front cover.
    • Use your fingers to remove the LCD screen.
    Where did you find a replacement part I need one myself?
    Luis - Yanıt
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
Adriana Rahrig
1.523 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Leahy Fall 2014 USF Tampa, Team 1-1, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S1G1
4 Üyeler
13 adet Kılavuz yazıldı
3 Yorum
please can anyone give me a website that sells replacemtn screens for the Gameboy pocket?
help please - Yanıt
There's no website that sells replacement screens the only way to get one is to order another Gameboy off of eBay and take out the screen
Isaac fraser -
I get mine from Handheld Legend. They have all the Gameboy parts you could ever want.
Chris Pavlik -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 65
Son 30 gün: 334
Her zaman: 22,601
