Ana içeriğe geç
Game Boy Pocket Power Button Replacement
Neye ihtiyacın var
  1. Game Boy Pocket Power Button Replacement, Remove the external screws: adım 1, 3 resimden 1. Game Boy Pocket Power Button Replacement, Remove the external screws: adım 1, 3 resimden 2. Game Boy Pocket Power Button Replacement, Remove the external screws: adım 1, 3 resimden 3.
    • Place the Game Boy Pocket face-down on a clean, flat surface.
    • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the four external screws.
    • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the two screws inside the battery compartment.
  2. Game Boy Pocket Power Button Replacement, Open the device: adım 2, 3 resimden 1. Game Boy Pocket Power Button Replacement, Open the device: adım 2, 3 resimden 2. Game Boy Pocket Power Button Replacement, Open the device: adım 2, 3 resimden 3.
    • Place your hands on the front and back covers of the Game Boy Pocket, and carefully separate the device.
    • Set the back cover aside. You will need it to reassemble the device.
  3. Game Boy Pocket Power Button Replacement, Remove the power button: adım 3, 3 resimden 1. Game Boy Pocket Power Button Replacement, Remove the power button: adım 3, 3 resimden 2. Game Boy Pocket Power Button Replacement, Remove the power button: adım 3, 3 resimden 3.
    • Use your fingers to remove the grey power button to the right of the ribbon cable.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Adriana Rahrig
1.637 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Leahy Fall 2014 USF Tampa, Team 1-1, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S1G1
4 Üyeler
19 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 20
Son 7 gün: 42
Son 30 gün: 414
Her zaman: 4,465
