Ana içeriğe geç
GameSir G7 SE Joystick Module Replacement
Neye ihtiyacın var
  1. GameSir G7 SE Joystick Module Replacement, Interior face plate: adım 1, 1 resimden 1.
    • Remove the faceplate by prying upwards with a plastic opening tool.
    • This faceplate is magnetic and will be easy to come off.
  2. GameSir G7 SE Joystick Module Replacement: adım 2, 2 resimden 1. GameSir G7 SE Joystick Module Replacement: adım 2, 2 resimden 2.
    • Use a T6 Torx Screwdriver to remove the six 9 mm screws from the interior face plate.
  3. GameSir G7 SE Joystick Module Replacement: adım 3, 2 resimden 1. GameSir G7 SE Joystick Module Replacement: adım 3, 2 resimden 2.
    • Using a plastic spudger tool, remove the interior face plate. Go around all the edges, prying downwards until it's removed.
    • Make sure to hold the controller upside down; otherwise the buttons will fall out.
  4. GameSir G7 SE Joystick Module Replacement, Joystick Module: adım 4, 1 resimden 1.
    • Remove the plastic joystick that is covering the joystick module by pulling up on from the gray grip.
  5. GameSir G7 SE Joystick Module Replacement: adım 5, 1 resimden 1.
    • To gain access to the joystick module, you will need to gently bend the metal retention clips that hold the module in place.
    • Use a plastic spudger to gently bend the retention clips back.
  6. GameSir G7 SE Joystick Module Replacement: adım 6, 1 resimden 1.
    • Pull directly up on the joystick module to remove it from the motherboard.
    • Make sure to hold the joystick module from the red portion to prevent it from falling apart.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
4Kılavuz Yorumları
Where to get the replacement parts?
Isaiah Hackworth - Yanıt
Where do you get the replacement parts from?
michaeljhs - Yanıt
Guida inutile senza ricambio
Matteo Andreani - Yanıt
Controller joystick fell apart on me. I used the video explaining the TMR sticks from gamesir to reassemble. Found this to find out I could fix it. Thank you a ton I fix it.
Devoid - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 20
Son 7 gün: 123
Son 30 gün: 543
Her zaman: 8,139
