Ana içeriğe geç
GameSir G7 SE Motherboard Replacement
Neye ihtiyacın var
  1. GameSir G7 SE Motherboard Replacement, Interior face plate: adım 1, 1 resimden 1.
    • Remove the faceplate by prying upwards with a plastic opening tool.
    • This faceplate is magnetic and will be easy to come off.
  2. GameSir G7 SE Motherboard Replacement: adım 2, 2 resimden 1. GameSir G7 SE Motherboard Replacement: adım 2, 2 resimden 2.
    • Use a T6 Torx Screwdriver to remove the six 9 mm screws from the interior face plate.
  3. GameSir G7 SE Motherboard Replacement: adım 3, 2 resimden 1. GameSir G7 SE Motherboard Replacement: adım 3, 2 resimden 2.
    • Using a plastic spudger tool, remove the interior face plate. Go around all the edges, prying downwards until it's removed.
    • Make sure to hold the controller upside down; otherwise the buttons will fall out.
  4. GameSir G7 SE Motherboard Replacement, Motherboard: adım 4, 1 resimden 1.
    • Use the Phillips #0 screwdriver bit to remove the four 9 mm screws holding the motherboard in place.
  5. GameSir G7 SE Motherboard Replacement: adım 5, 1 resimden 1.
    • Pull straight up on the board to remove the motherboard and connecting components
    • Be careful to not dislodge the back buttons from the back plate housing
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Hello,where did you find or buy a new motherboard for this?
DavidofSlim7 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 24
Son 30 gün: 128
Her zaman: 2,099
