Ana içeriğe geç
GameSir T4 Pro Battery Replacement
Neye ihtiyacın var
  1. GameSir T4 Pro Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Using the Phillips 1 screwdriver, gently turn the screw to the left (repeat this step until all four screws are taken out).
  2. GameSir T4 Pro Battery Replacement: adım 2, 1 resimden 1.
    • Use your iFixit opening tool to break the seam of the back of your controller.
    • Be careful when pulling apart, as the charging port wires are connected to both sides of the controller.
  3. GameSir T4 Pro Battery Replacement: adım 3, 1 resimden 1.
    • Using the plastic spudger, wiggle the connection out of place.
  4. GameSir T4 Pro Battery Replacement: adım 4, 1 resimden 1.
    • Apply a slow, but consistent pull to the old 600 maH battery.
    • Attach new battery onto the pad.
Sonuç
Bir başkası bu kılavuzu tamamladı.
3 Yorum
Battery Model is pl502450 600mah
3.7v
Eugene Eugenio - Yanıt
Where can I buy this battery? Do You have a link to it?
Roberto Barros -
Roberto Barros - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 29
Son 30 gün: 105
Her zaman: 1,817
