Giriş
Use this guide to remove the battery from your GameSit T4 Pro controller. All you need for this repair is a Phillips #1 screwdriver and the iFixit opening tool. For the battery replacement, this controller requires a 600 maH battery. Complete this repair guide before continuing to the other repair guides.
Neye ihtiyacın var
Using the Phillips 1 screwdriver, gently turn the screw to the left (repeat this step until all four screws are taken out).
Bir başkası bu kılavuzu tamamladı.
3Kılavuz Yorumları
Battery Model is pl502450 600mah
3.7v
Where can I buy this battery? Do You have a link to it?
