Ana içeriğe geç
GameSir T4 Pro Bumper Replacement
Neye ihtiyacın var
  1. GameSir T4 Pro Bumper Replacement, Bumper: adım 1, 3 resimden 1. GameSir T4 Pro Bumper Replacement, Bumper: adım 1, 3 resimden 2. GameSir T4 Pro Bumper Replacement, Bumper: adım 1, 3 resimden 3.
    • Remove the following screws on the back case using a Phillips screwdriver:
    • Two 9.2 mm
    • Two 11.3 mm
    • Insert an opening tool in the seam between the front and back case.
    • Pry around the perimeter until the back case releases.
  2. GameSir T4 Pro Bumper Replacement: adım 2, 1 resimden 1.
    • Disconnect the USB-C charger with tweezers.
    • Do not pull on the wires.
  3. GameSir T4 Pro Bumper Replacement: adım 3, 2 resimden 1. GameSir T4 Pro Bumper Replacement: adım 3, 2 resimden 2.
    • Remove the two 7.1 mm Phillips screws that secure the shoulder buttons.
  4. GameSir T4 Pro Bumper Replacement: adım 4, 1 resimden 1.
    • Gently lift up the plastic piece holding the bumper and trigger.
    • Remove the bumper.
Sonuç
Yamini Sri
355 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-2, Harley Spring 2024 IUPUI, Team 1-2, Harley Spring 2024 üyesi
IUPUI-HARLEY-S24S1G2
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 39
Her zaman: 136
