Ana içeriğe geç
GameSir T4 Pro Charging Port Replacement
Neye ihtiyacın var
  1. GameSir T4 Pro Charging Port Replacement, Battery: adım 1, 1 resimden 1.
    • Using the Phillips 1 screwdriver, gently turn the screw to the left (repeat this step until all four screws are taken out).
  2. GameSir T4 Pro Charging Port Replacement: adım 2, 1 resimden 1.
    • Use your iFixit opening tool to break the seam of the back of your controller.
    • Be careful when pulling apart, as the charging port wires are connected to both sides of the controller.
  3. GameSir T4 Pro Charging Port Replacement: adım 3, 1 resimden 1.
    • Using the plastic spudger, wiggle the connection out of place.
  4. GameSir T4 Pro Charging Port Replacement: adım 4, 1 resimden 1.
    • Apply a slow, but consistent pull to the old 600 maH battery.
    • Attach new battery onto the pad.
  5. GameSir T4 Pro Charging Port Replacement, Charging Port: adım 5, 2 resimden 1. GameSir T4 Pro Charging Port Replacement, Charging Port: adım 5, 2 resimden 2.
    • Use the needle nose pliers to remove the plastic connection from the motherboard.
    • You may hold the wires for stability, but do not tug on the wires.
  6. GameSir T4 Pro Charging Port Replacement: adım 6, 2 resimden 1. GameSir T4 Pro Charging Port Replacement: adım 6, 2 resimden 2.
    • Remove the two 5mm screws on the charging port and take out the old charging port.
  7. GameSir T4 Pro Charging Port Replacement: adım 7, 2 resimden 1. GameSir T4 Pro Charging Port Replacement: adım 7, 2 resimden 2.
    • Put your new compatible charging port in place.
    • Make sure to screw in the 5mm screws into your new charing port
Sonuç
Bir Yorum
Where i can buy the charging port? Some buttons isnt working so when i was trying to solve the problem with contact cleaner i ended up breaking the soldered connection
Eron Araújo - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 31
Her zaman: 777
