Ana içeriğe geç
GameSir T4 Pro Directional Pad Replacement
Neye ihtiyacın var
  1. GameSir T4 Pro Directional Pad Replacement, Battery: adım 1, 1 resimden 1.
    • Using the Phillips 1 screwdriver, gently turn the screw to the left (repeat this step until all four screws are taken out).
  2. GameSir T4 Pro Directional Pad Replacement: adım 2, 1 resimden 1.
    • Use your iFixit opening tool to break the seam of the back of your controller.
    • Be careful when pulling apart, as the charging port wires are connected to both sides of the controller.
  3. GameSir T4 Pro Directional Pad Replacement: adım 3, 1 resimden 1.
    • Using the plastic spudger, wiggle the connection out of place.
  4. GameSir T4 Pro Directional Pad Replacement: adım 4, 1 resimden 1.
    • Apply a slow, but consistent pull to the old 600 maH battery.
    • Attach new battery onto the pad.
  5. GameSir T4 Pro Directional Pad Replacement, Directional Pad: adım 5, 2 resimden 1. GameSir T4 Pro Directional Pad Replacement, Directional Pad: adım 5, 2 resimden 2.
    • To get to the directional pad (d-pad), remove the three 5mm screws on the motherboard.
  6. GameSir T4 Pro Directional Pad Replacement: adım 6, 1 resimden 1.
    • Disconnect all white connectors from the motherboard.
  7. GameSir T4 Pro Directional Pad Replacement: adım 7, 1 resimden 1.
    • Carefully pull the motherboard away to reveal the front panel.
  8. GameSir T4 Pro Directional Pad Replacement: adım 8, 1 resimden 1.
    • Remove the d-pad from the front panel.
  9. GameSir T4 Pro Directional Pad Replacement: adım 9, 1 resimden 1.
    • Place your new d-pad in place.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 33
Her zaman: 709
