Ana içeriğe geç
GameSir T4 Pro Motherboard Replacement
Neye ihtiyacın var
  1. GameSir T4 Pro Motherboard Replacement, Motherboard: adım 1, 3 resimden 1. GameSir T4 Pro Motherboard Replacement, Motherboard: adım 1, 3 resimden 2. GameSir T4 Pro Motherboard Replacement, Motherboard: adım 1, 3 resimden 3.
    • Remove the following screws on the back case using a Phillips screwdriver:
    • Two 9.2 mm
    • Two 11.3 mm
    • Insert an opening tool in the seam between the front and back case.
    • Pry around the perimeter until the back case releases.
  2. GameSir T4 Pro Motherboard Replacement: adım 2, 2 resimden 1. GameSir T4 Pro Motherboard Replacement: adım 2, 2 resimden 2.
    • Disconnect the USB-C charger with tweezers.
    • Do not pull on the wires.
  3. GameSir T4 Pro Motherboard Replacement: adım 3, 1 resimden 1.
    • Gently pry the battery off of the motherboard, with care not to bend the cell.
    • The battery is secured with adhesive. If the adhesive is stubborn, apply a small amount of high-concentration alcohol under the battery to loosen the adhesive.
    • Grip the white battery connector with tweezers and pull it directly out of its motherboard port.
  4. GameSir T4 Pro Motherboard Replacement: adım 4, 2 resimden 1. GameSir T4 Pro Motherboard Replacement: adım 4, 2 resimden 2.
    • Remove the three 7.1 mm Phillips #0 screws from the motherboard.
    • Remove the two 7.1 mm Phillips #0 screws that secure the trigger assemblies.
  5. GameSir T4 Pro Motherboard Replacement: adım 5, 1 resimden 1.
    • Lift the motherboard out of the controller.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Yamini Sri
355 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-2, Harley Spring 2024 IUPUI, Team 1-2, Harley Spring 2024 üyesi
IUPUI-HARLEY-S24S1G2
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 39
Her zaman: 681
