Ana içeriğe geç
GameSir T4 Pro Vibration Motor Replacement
Neye ihtiyacın var
  1. GameSir T4 Pro Vibration Motor Replacement, Vibration Motor: adım 1, 3 resimden 1. GameSir T4 Pro Vibration Motor Replacement, Vibration Motor: adım 1, 3 resimden 2. GameSir T4 Pro Vibration Motor Replacement, Vibration Motor: adım 1, 3 resimden 3.
    • Remove the following screws on the back case using a Phillips screwdriver:
    • Two 9.2 mm
    • Two 11.3 mm
    • Insert an opening tool in the seam between the front and back case.
    • Pry around the perimeter until the back case releases.
  2. GameSir T4 Pro Vibration Motor Replacement: adım 2, 1 resimden 1.
    • Use tweezers to pull the right vibration motor connector directly out of its motherboard port.
    • Do not pull on the wires to disconnect the cable.
    • Repeat on the left vibration motor if necessary.
  3. GameSir T4 Pro Vibration Motor Replacement: adım 3, 1 resimden 1.
    • Remove the right vibration motor from its housing.
    • Repeat on the left side if necessary.
Sonuç
Yamini Sri
355 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-2, Harley Spring 2024 IUPUI, Team 1-2, Harley Spring 2024 üyesi
IUPUI-HARLEY-S24S1G2
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 90
