Ana içeriğe geç
GameStop GS3 GameCube Controller Buttons Replacement
Neye ihtiyacın var
  1. GameStop GS3 GameCube Controller Buttons Replacement, Back Panel: adım 1, 3 resimden 1. GameStop GS3 GameCube Controller Buttons Replacement, Back Panel: adım 1, 3 resimden 2. GameStop GS3 GameCube Controller Buttons Replacement, Back Panel: adım 1, 3 resimden 3.
    • First, remove the 6 screws in the back panel and pull the back panel off.
    • Separate the halves of the controller. However, be careful when separating due to the little wires that could get mixed up.
    FixBot'a Sor
    Yorum Ekle
  2. GameStop GS3 GameCube Controller Buttons Replacement: adım 2, 3 resimden 1. GameStop GS3 GameCube Controller Buttons Replacement: adım 2, 3 resimden 2. GameStop GS3 GameCube Controller Buttons Replacement: adım 2, 3 resimden 3.
    • Next, remove the rumble motor by unscrewing the 2 screws connecting it.
    FixBot'a Sor
    Yorum Ekle
  3. GameStop GS3 GameCube Controller Buttons Replacement: adım 3, 3 resimden 1. GameStop GS3 GameCube Controller Buttons Replacement: adım 3, 3 resimden 2. GameStop GS3 GameCube Controller Buttons Replacement: adım 3, 3 resimden 3.
    • Finally remove the screws holding in the right and left triggers. It's easiest to hold the trigger together as shown in the third picture. Remove both the left and right trigger, and then you have successfully removed your back panel.
    FixBot'a Sor
    Yorum Ekle
  4. GameStop GS3 GameCube Controller Buttons Replacement, Buttons: adım 4, 1 resimden 1.
    • Hold the controller as shown in the picture so that you can remove the circuit board.
    • The locations of screws to be removed in future steps are shown in red.
    FixBot'a Sor
    Yorum Ekle
  5. GameStop GS3 GameCube Controller Buttons Replacement: adım 5, 2 resimden 1. GameStop GS3 GameCube Controller Buttons Replacement: adım 5, 2 resimden 2.
    • Now that the back panel has been removed it should be easy to snap off the "Z" and "TURBO" buttons as shown in the images.
    FixBot'a Sor
    Yorum Ekle
  6. GameStop GS3 GameCube Controller Buttons Replacement: adım 6, 1 resimden 1.
    • Remove the two screws on the motherboard so that you can remove the motherboard from the front cover.
    FixBot'a Sor
    Yorum Ekle
  7. GameStop GS3 GameCube Controller Buttons Replacement: adım 7, 1 resimden 1.
    • Now your controller front panel should look similar to this.
    • Remove the rubber backings on the buttons shown in red.
    • Snap them back in when you go to put the controller back together.
    FixBot'a Sor
    Yorum Ekle
  8. GameStop GS3 GameCube Controller Buttons Replacement: adım 8, 1 resimden 1.
    • Remove the buttons and you should have what you see here.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Andrew Gonsalves
238 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-5, Isaacson Fall 2016 UMass Dartmouth, Team 3-5, Isaacson Fall 2016 üyesi
UMASSD-ISAACSON-F16S3G5
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 30
Her zaman: 1,407
