Ana içeriğe geç
GameStop GS3 GameCube Controller Motherboard Replacement
Neye ihtiyacın var
  1. GameStop GS3 GameCube Controller Motherboard Replacement, Motherboard: adım 1, 2 resimden 1. GameStop GS3 GameCube Controller Motherboard Replacement, Motherboard: adım 1, 2 resimden 2.
    • Open the controller by unscrewing the screws located on the back panel
    • Separate the two halves of the controller.
  2. GameStop GS3 GameCube Controller Motherboard Replacement: adım 2, 3 resimden 1. GameStop GS3 GameCube Controller Motherboard Replacement: adım 2, 3 resimden 2. GameStop GS3 GameCube Controller Motherboard Replacement: adım 2, 3 resimden 3.
    • Remove the rumble-pack by unscrewing the screws located on on either side.
    • Remove the rumble pack to fully separate the two halves of the controller
  3. GameStop GS3 GameCube Controller Motherboard Replacement: adım 3, 3 resimden 1. GameStop GS3 GameCube Controller Motherboard Replacement: adım 3, 3 resimden 2. GameStop GS3 GameCube Controller Motherboard Replacement: adım 3, 3 resimden 3.
    • Disconnect the motherboard from the front half of the controller by unscrewing the small screws around its perimeter.
    • The motherboard should separate and lift right out from the front half.
Sonuç
John Harrison
213 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-5, Isaacson Fall 2016 UMass Dartmouth, Team 3-5, Isaacson Fall 2016 üyesi
UMASSD-ISAACSON-F16S3G5
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 881
