Ana içeriğe geç
GameStop GS3 GameCube Controller joysticks replacement
Neye ihtiyacın var
  1. GameStop GS3 GameCube Controller joysticks replacement, Joysticks: adım 1, 2 resimden 1. GameStop GS3 GameCube Controller joysticks replacement, Joysticks: adım 1, 2 resimden 2.
    • Loosen and remove the 6 screws located on the back of the controller using your Phillips Screwdriver.
  2. GameStop GS3 GameCube Controller joysticks replacement: adım 2, 1 resimden 1.
    • Carefully pry apart the top and bottom covers.
  3. GameStop GS3 GameCube Controller joysticks replacement: adım 3, 3 resimden 1. GameStop GS3 GameCube Controller joysticks replacement: adım 3, 3 resimden 2. GameStop GS3 GameCube Controller joysticks replacement: adım 3, 3 resimden 3.
    • After separation, locate the rumble motor that is attached to the bottom cover of the controller.
    • Loosen and remove the 2 screws that are holding the rumble motor in place.
    • Lift and remove the rumble motor from the case.
  4. GameStop GS3 GameCube Controller joysticks replacement: adım 4, 3 resimden 1. GameStop GS3 GameCube Controller joysticks replacement: adım 4, 3 resimden 2. GameStop GS3 GameCube Controller joysticks replacement: adım 4, 3 resimden 3.
    • On the top cover of the controller, locate the green portion of the motherboard.
    • Loosen and remove the 1 screw in the upper left side of the green motherboard.
    • Turn the green motherboard over and attached to the motherboard will be the yellow c-stick.
    • Firmly, but carefully, pull the c-stick off, and clean around the area before reattaching or replacing the c-stick.
    • After cleaning or replacing the c-stick, reattach the green motherboard piece to the orange motherboard piece.
  5. GameStop GS3 GameCube Controller joysticks replacement: adım 5, 3 resimden 1. GameStop GS3 GameCube Controller joysticks replacement: adım 5, 3 resimden 2. GameStop GS3 GameCube Controller joysticks replacement: adım 5, 3 resimden 3.
    • Finally, loosen and remove the 2 screws located on the orange motherboard.
    • Pull up and remove the motherboard from the top cover. Then turn the motherboard over.
    • Locate the gray joystick that is attached to the left side of the motherboard.
    • Similarly to the yellow c-stick, firmly, but carefully, pull the gray joystick off, and clean around the area before reattaching or replacing the joystick.
Sonuç
Andrew Gonsalves
226 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-5, Isaacson Fall 2016 UMass Dartmouth, Team 3-5, Isaacson Fall 2016 üyesi
UMASSD-ISAACSON-F16S3G5
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 30
Her zaman: 1,385
