Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Gently remove the safety laser connectors by pressing down the release tabs using a small, flathead screwdriver to release the wires.
There is a handle located at the top of the door for manually releasing the door from the chain rail. Firmly pull this release handle to disconnect the opener from the door.
Your existing motor is mounted on a frame attached to the ceiling. Unscrew the bolts on the mounting frame with a ratchet to remove the opener.
Loosen up the nuts and washers that hold the chain to the unit. This loosens the chain and prevents the chain from springing back.
You are almost at the halfway point. Take the chain off and lubricate it with WD-40.
Wipe down the chain with a cloth and put it to the side.
Loosen up the bolts that hold the opener unit to the chain rail.
Remove the garage door motor unit.
Some readers may find that they need new laser sensors. Your preexisting sensors are most likely stapled into the wall and ceiling. Remove the sensors from the garage.
Install the new sensors and route the wires to the opener. Staple the wires into the wall as neatly as possible.
Your new opener comes with preset bolts that need to be taken off. Once you have the bolts, it's time to follow the steps in reverse order to put the opener back onto the mounting frame.
Bir başkası bu kılavuzu tamamladı.
