Ana içeriğe geç
Garmin Approach S2 Battery Replacement
Neye ihtiyacın var
  1. Garmin Approach S2 Battery Replacement, Back Cover: adım 1, 2 resimden 1. Garmin Approach S2 Battery Replacement, Back Cover: adım 1, 2 resimden 2.
    • Remove the six T5 Torx 6.32mm screws securing the back cover to the watch.
  2. Garmin Approach S2 Battery Replacement: adım 2, 1 resimden 1.
    • Remove the back cover carefully.
    • Even after the screws have been removed, the back cover can still be quite difficult to take off. Moderate to extensive prying may be required. Be gentle, but firm.
  3. Garmin Approach S2 Battery Replacement, Battery: adım 3, 1 resimden 1.
    • On the back cover use a plastic opening tool to remove the green tape retaining the battery.
  4. Garmin Approach S2 Battery Replacement: adım 4, 2 resimden 1. Garmin Approach S2 Battery Replacement: adım 4, 2 resimden 2.
    • Remove the green tape shrouding the battery connector.
  5. Garmin Approach S2 Battery Replacement: adım 5, 2 resimden 1. Garmin Approach S2 Battery Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use the ESD safe tweezers to push the connector and metal shroud out from the back of the connector.
    • Remove the third and fourth wires from the right of the connector (as seen when looking from the angle in the photo). They should be red and black respectively.
    • DO NOT attempt to pull the wire from the connector, it will pull the wire from the metal shroud shown in the red box, which needs to be preserved for the connection to be successful.
  6. Garmin Approach S2 Battery Replacement: adım 6, 1 resimden 1.
    • Use the ESD safe tweezers to break the adhesive between the back cover and the battery.
    • Remove the battery.
  7. Garmin Approach S2 Battery Replacement: adım 7, 1 resimden 1.
    • Remove the green tape on the back of the battery, it can be reused later.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Emily Kovacs
259 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S4-G1, Baechle Spring 2018 IUPUI, Team S4-G1, Baechle Spring 2018 üyesi
IUPUI-BAECHLE-S18S4G1
3 Üyeler
4 adet Kılavuz yazıldı
8Kılavuz Yorumları
If anyone is looking for the replacement battery for the Approach S2 it can be found here:
Replacement Battery for Garmin Approach S2
It also included the T5 Torx and Opening Tools that are needed.
michaelf33707 - Yanıt
Step 6 shows 2 red wires each with a free end. One of these red wires has the non free end connected to the charging circuit terminal but there is no mention in Step 6 of disconnecting this wire or where the free end is connected to.
Paul Stevenson - Yanıt
This is a great tutorial for the S2. In my case I accidentally dropped one metal shroud (referred to in Step 5). I scoured the area on my hands and knees to no avail. Can you direct me to where I might obtain this part?or perhaps the entire connector? Thank you….
Brian Mahoney - Yanıt
Hi, Where the !&&* Can I buy a Replacement Battery for The Garmin S2 Golf watch.????.
Gregory John Wickenden - Yanıt
Gregory, I got my replacement via Amazon (UK). Battery came from Germany in about 1 week. Not cheap, but a lot cheaper than a new watch.
john.joice - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 53
Son 30 gün: 245
Her zaman: 41,618
