Ana içeriğe geç
Garmin Dash Cam 20 Battery Replacement
Neye ihtiyacın var
  1. Garmin Dash Cam 20 Battery Replacement, Internal Assembly: adım 1, 2 resimden 1. Garmin Dash Cam 20 Battery Replacement, Internal Assembly: adım 1, 2 resimden 2.
    • Be sure to turn off the Dash Cam by pressing the power button.
  2. Garmin Dash Cam 20 Battery Replacement: adım 2, 2 resimden 1. Garmin Dash Cam 20 Battery Replacement: adım 2, 2 resimden 2.
    • Rotate the Dash Cam to where the socket faces you.
    • Remove the 9 mm screw using the Torx T6 screwdriver.
  3. Garmin Dash Cam 20 Battery Replacement: adım 3, 2 resimden 1. Garmin Dash Cam 20 Battery Replacement: adım 3, 2 resimden 2.
    • Remove the Dash Cam socket piece.
  4. Garmin Dash Cam 20 Battery Replacement: adım 4, 2 resimden 1. Garmin Dash Cam 20 Battery Replacement: adım 4, 2 resimden 2.
    • Rotate the Dash Cam to where the product information faces you.
    • Remove the two 5 mm screws using the Torx T5 screwdriver.
  5. Garmin Dash Cam 20 Battery Replacement: adım 5, 3 resimden 1. Garmin Dash Cam 20 Battery Replacement: adım 5, 3 resimden 2. Garmin Dash Cam 20 Battery Replacement: adım 5, 3 resimden 3.
    • Remove top case from the bottom case.
    • The compact nature of the casing requires use of the metal spudger for needed leverage.
  6. Garmin Dash Cam 20 Battery Replacement: adım 6, 3 resimden 1. Garmin Dash Cam 20 Battery Replacement: adım 6, 3 resimden 2. Garmin Dash Cam 20 Battery Replacement: adım 6, 3 resimden 3.
    • Remove the two 5mm screws using the Torx T5 screwdriver
    • By removing the screws, the metal battery frame will now become free from the rest of the device.
  7. Garmin Dash Cam 20 Battery Replacement, Battery: adım 7, 3 resimden 1. Garmin Dash Cam 20 Battery Replacement, Battery: adım 7, 3 resimden 2. Garmin Dash Cam 20 Battery Replacement, Battery: adım 7, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the green tape overlying the pin connector with tweezers.
    • Remove the pin connector using tweezers.
    • Do not break black cord connection between motherboard and metal mount (orange circle).
  8. Garmin Dash Cam 20 Battery Replacement: adım 8, 3 resimden 1. Garmin Dash Cam 20 Battery Replacement: adım 8, 3 resimden 2. Garmin Dash Cam 20 Battery Replacement: adım 8, 3 resimden 3.
    • This step shows the use of an incorrect tool. Only use ESD safe tools when handling the battery.
    • With the the nylon spudger, lift the battery to expose and stretch the glue. Cut the glue residue by gliding the tool from left to right.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Jesse Hillman
757 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-1, Cagle Fall 2016 USF Tampa, Team 2-1, Cagle Fall 2016 üyesi
USFT-CAGLE-F16S2G1
4 Üyeler
3 Yorum
An excellent article except for one major problem but, why does iFixIt not sell theses batteries or direct you on where a person could actually buy one? This knowledge is pretty much useless with out a replacement battery to actually use.
Bradley Hyman - Yanıt
Yeah I agree
Yousef Ghalib -
Thanks for this guide. This gave my Garmin 20 another couple of years! :)
BTW, I was able to buy the battery replacement from Amazon: https://www.amazon.com/gp/product/B07KSR...
pro cabales - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 54
Her zaman: 3,956
