Ana içeriğe geç
Garmin Dash Cam 20 Motherboard Replacement
Neye ihtiyacın var
  1. Garmin Dash Cam 20 Motherboard Replacement, Internal Assembly: adım 1, 2 resimden 1. Garmin Dash Cam 20 Motherboard Replacement, Internal Assembly: adım 1, 2 resimden 2.
    • Be sure to turn off the Dash Cam by pressing the power button.
  2. Garmin Dash Cam 20 Motherboard Replacement: adım 2, 2 resimden 1. Garmin Dash Cam 20 Motherboard Replacement: adım 2, 2 resimden 2.
    • Rotate the Dash Cam to where the socket faces you.
    • Remove the 9 mm screw using the Torx T6 screwdriver.
  3. Garmin Dash Cam 20 Motherboard Replacement: adım 3, 2 resimden 1. Garmin Dash Cam 20 Motherboard Replacement: adım 3, 2 resimden 2.
    • Remove the Dash Cam socket piece.
  4. Garmin Dash Cam 20 Motherboard Replacement: adım 4, 2 resimden 1. Garmin Dash Cam 20 Motherboard Replacement: adım 4, 2 resimden 2.
    • Rotate the Dash Cam to where the product information faces you.
    • Remove the two 5 mm screws using the Torx T5 screwdriver.
  5. Garmin Dash Cam 20 Motherboard Replacement: adım 5, 3 resimden 1. Garmin Dash Cam 20 Motherboard Replacement: adım 5, 3 resimden 2. Garmin Dash Cam 20 Motherboard Replacement: adım 5, 3 resimden 3.
    • Remove top case from the bottom case.
    • The compact nature of the casing requires use of the metal spudger for needed leverage.
  6. Garmin Dash Cam 20 Motherboard Replacement: adım 6, 3 resimden 1. Garmin Dash Cam 20 Motherboard Replacement: adım 6, 3 resimden 2. Garmin Dash Cam 20 Motherboard Replacement: adım 6, 3 resimden 3.
    • Remove the two 5mm screws using the Torx T5 screwdriver
    • By removing the screws, the metal battery frame will now become free from the rest of the device.
  7. Garmin Dash Cam 20 Motherboard Replacement, Motherboard Components: adım 7, 2 resimden 1. Garmin Dash Cam 20 Motherboard Replacement, Motherboard Components: adım 7, 2 resimden 2.
    • This step shows the use of an incorrect tool. Always use an ESD safe tool, like a nylon spudger, when working with delicate internal components.
    • Use the nylon spudger to pry the corner of the case off of the motherboard.
  8. Garmin Dash Cam 20 Motherboard Replacement: adım 8, 3 resimden 1. Garmin Dash Cam 20 Motherboard Replacement: adım 8, 3 resimden 2. Garmin Dash Cam 20 Motherboard Replacement: adım 8, 3 resimden 3.
    • Remove the metal case off of the motherboard.
  9. Garmin Dash Cam 20 Motherboard Replacement: adım 9, 3 resimden 1. Garmin Dash Cam 20 Motherboard Replacement: adım 9, 3 resimden 2. Garmin Dash Cam 20 Motherboard Replacement: adım 9, 3 resimden 3.
    • Remove the battery connection.
  10. Garmin Dash Cam 20 Motherboard Replacement: adım 10, 3 resimden 1. Garmin Dash Cam 20 Motherboard Replacement: adım 10, 3 resimden 2. Garmin Dash Cam 20 Motherboard Replacement: adım 10, 3 resimden 3.
    • Remove the three 5 mm screws using the Torx T5 screwdriver.
  11. Garmin Dash Cam 20 Motherboard Replacement: adım 11, 3 resimden 1. Garmin Dash Cam 20 Motherboard Replacement: adım 11, 3 resimden 2. Garmin Dash Cam 20 Motherboard Replacement: adım 11, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers to remove the connector on the top right of the motherboard.
  12. Garmin Dash Cam 20 Motherboard Replacement: adım 12, 3 resimden 1. Garmin Dash Cam 20 Motherboard Replacement: adım 12, 3 resimden 2. Garmin Dash Cam 20 Motherboard Replacement: adım 12, 3 resimden 3.
    • Remove the motherboard from the case and flip to reveal SD connection.
    • Use tweezers to remove the connector next to the SD card slot.
  13. Garmin Dash Cam 20 Motherboard Replacement: adım 13, 1 resimden 1.
    • The motherboard is now removed aside from the copper strip and its connector.
    • Disconnect from the front case and the copper strip.
Sonuç
Jesse Hillman
757 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-1, Cagle Fall 2016 USF Tampa, Team 2-1, Cagle Fall 2016 üyesi
USFT-CAGLE-F16S2G1
4 Üyeler
Bir Yorum
hello Im looking for a replacement part for this Dash Cam, the socket piece. Do you have any of them?
rdlr2112@gmail.com
rushfanbytor - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 20
Her zaman: 848
