Ana içeriğe geç
Garmin Dash Cam 20 Screen Replacement
Neye ihtiyacın var
  1. Garmin Dash Cam 20 Screen Replacement, Internal Assembly: adım 1, 2 resimden 1. Garmin Dash Cam 20 Screen Replacement, Internal Assembly: adım 1, 2 resimden 2.
    • Be sure to turn off the Dash Cam by pressing the power button.
  2. Garmin Dash Cam 20 Screen Replacement: adım 2, 2 resimden 1. Garmin Dash Cam 20 Screen Replacement: adım 2, 2 resimden 2.
    • Rotate the Dash Cam to where the socket faces you.
    • Remove the 9 mm screw using the Torx T6 screwdriver.
  3. Garmin Dash Cam 20 Screen Replacement: adım 3, 2 resimden 1. Garmin Dash Cam 20 Screen Replacement: adım 3, 2 resimden 2.
    • Remove the Dash Cam socket piece.
  4. Garmin Dash Cam 20 Screen Replacement: adım 4, 2 resimden 1. Garmin Dash Cam 20 Screen Replacement: adım 4, 2 resimden 2.
    • Rotate the Dash Cam to where the product information faces you.
    • Remove the two 5 mm screws using the Torx T5 screwdriver.
  5. Garmin Dash Cam 20 Screen Replacement: adım 5, 3 resimden 1. Garmin Dash Cam 20 Screen Replacement: adım 5, 3 resimden 2. Garmin Dash Cam 20 Screen Replacement: adım 5, 3 resimden 3.
    • Remove top case from the bottom case.
    • The compact nature of the casing requires use of the metal spudger for needed leverage.
  6. Garmin Dash Cam 20 Screen Replacement: adım 6, 3 resimden 1. Garmin Dash Cam 20 Screen Replacement: adım 6, 3 resimden 2. Garmin Dash Cam 20 Screen Replacement: adım 6, 3 resimden 3.
    • Remove the two 5mm screws using the Torx T5 screwdriver
    • By removing the screws, the metal battery frame will now become free from the rest of the device.
  7. Garmin Dash Cam 20 Screen Replacement, Screen: adım 7, 3 resimden 1. Garmin Dash Cam 20 Screen Replacement, Screen: adım 7, 3 resimden 2. Garmin Dash Cam 20 Screen Replacement, Screen: adım 7, 3 resimden 3.
    • Use the Phillips screwdriver to remove the four 5mm screws.
  8. Garmin Dash Cam 20 Screen Replacement: adım 8, 2 resimden 1. Garmin Dash Cam 20 Screen Replacement: adım 8, 2 resimden 2.
    • Use the metal spudger to remove metal plate from device. This will reveal the screen.
  9. Garmin Dash Cam 20 Screen Replacement: adım 9, 3 resimden 1. Garmin Dash Cam 20 Screen Replacement: adım 9, 3 resimden 2. Garmin Dash Cam 20 Screen Replacement: adım 9, 3 resimden 3.
    • Use the metal spudger to remove screen from device.
  10. Garmin Dash Cam 20 Screen Replacement: adım 10, 1 resimden 1.
    • The screen is now detached.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jesse Hillman
757 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-1, Cagle Fall 2016 USF Tampa, Team 2-1, Cagle Fall 2016 üyesi
USFT-CAGLE-F16S2G1
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 471
