Giriş
This guide will explain how to open your Garmin, detach the battery from the motherboard, and remove the battery from the device safely and quickly.
Neye ihtiyacın var
Using a Torx T6 Screwdriver, remove the ten 7mm screws from the back panel.
6 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
Completely useless as soon as you open the cover the old ribbon rips and you garmin is junk. Don’t waste your money
you have to be more careful with your stuff dude..
