Ana içeriğe geç
Garmin Dezl 760LMT Motherboard Replacement
Neye ihtiyacın var
  1. Garmin Dezl 760LMT Motherboard Replacement, Back Panel: adım 1, 2 resimden 1. Garmin Dezl 760LMT Motherboard Replacement, Back Panel: adım 1, 2 resimden 2.
    • Using a Torx T6 Screwdriver, remove the ten 7mm screws from the back panel.
  2. Garmin Dezl 760LMT Motherboard Replacement: adım 2, 3 resimden 1. Garmin Dezl 760LMT Motherboard Replacement: adım 2, 3 resimden 2. Garmin Dezl 760LMT Motherboard Replacement: adım 2, 3 resimden 3.
    • Using a metal spudger, pry the device apart.
    • To recombine them, line up the two halves of the device and press them together.
  3. Garmin Dezl 760LMT Motherboard Replacement: adım 3, 1 resimden 1.
    • Turn the device over, laying it on its back with the screen facing upwards.
    • Lift the front panel away from the silver part of the back panel.
    • Make sure not to rip the ribbon cable that is connected to the screen and the motherboard.
  4. Garmin Dezl 760LMT Motherboard Replacement, Screen Ribbon Cable: adım 4, 2 resimden 1. Garmin Dezl 760LMT Motherboard Replacement, Screen Ribbon Cable: adım 4, 2 resimden 2.
    • Lift the screen opposite where the "GARMIN" logo is located. Remove the clear tape holding the ribbon cable to the motherboard.
  5. Garmin Dezl 760LMT Motherboard Replacement: adım 5, 2 resimden 1. Garmin Dezl 760LMT Motherboard Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    • Find and lift the small grey hinge at the end of the ribbon cable.
    • When handling the motherboard, make sure to wear an anti-static wrist strap.
  6. Garmin Dezl 760LMT Motherboard Replacement, Motherboard: adım 6, 2 resimden 1. Garmin Dezl 760LMT Motherboard Replacement, Motherboard: adım 6, 2 resimden 2.
    • Using a Torx T5 screwdriver, unscrew the six 5mm screws on the motherboard.
  7. Garmin Dezl 760LMT Motherboard Replacement: adım 7, 3 resimden 1. Garmin Dezl 760LMT Motherboard Replacement: adım 7, 3 resimden 2. Garmin Dezl 760LMT Motherboard Replacement: adım 7, 3 resimden 3.
    • Grasp each of the three wires near where it is attached to the motherboard. Lift them upward to detach them.
    • Lift the motherboard from the device.
Sonuç
Ryan Williams
763 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-2, Passmore Fall 2016 USF Tampa, Team 4-2, Passmore Fall 2016 üyesi
USFT-PASSMORE-F16S4G2
4 Üyeler
2 Yorum
i realy appreciate the video but please tell me where can i find buy the motherboard or others parts for my gps rv-760
Thank you
Pierre Delisle
Québec
Canada
Pierre Delisle - Yanıt
Is it possible to buy the ribbon cable from the screen to the mother board, and what’s the procedure to replace it on the display ? Thanks
Kiki B - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 2,964
