Ana içeriğe geç
Garmin Dezl 760LMT Screen Replacement
Neye ihtiyacın var
  1. Garmin Dezl 760LMT Screen Replacement, Back Panel: adım 1, 2 resimden 1. Garmin Dezl 760LMT Screen Replacement, Back Panel: adım 1, 2 resimden 2.
    • Using a Torx T6 Screwdriver, remove the ten 7mm screws from the back panel.
  2. Garmin Dezl 760LMT Screen Replacement: adım 2, 3 resimden 1. Garmin Dezl 760LMT Screen Replacement: adım 2, 3 resimden 2. Garmin Dezl 760LMT Screen Replacement: adım 2, 3 resimden 3.
    • Using a metal spudger, pry the device apart.
    • To recombine them, line up the two halves of the device and press them together.
  3. Garmin Dezl 760LMT Screen Replacement: adım 3, 1 resimden 1.
    • Turn the device over, laying it on its back with the screen facing upwards.
    • Lift the front panel away from the silver part of the back panel.
    • Make sure not to rip the ribbon cable that is connected to the screen and the motherboard.
  4. Garmin Dezl 760LMT Screen Replacement, Screen Ribbon Cable: adım 4, 2 resimden 1. Garmin Dezl 760LMT Screen Replacement, Screen Ribbon Cable: adım 4, 2 resimden 2.
    • Lift the screen opposite where the "GARMIN" logo is located. Remove the clear tape holding the ribbon cable to the motherboard.
  5. Garmin Dezl 760LMT Screen Replacement: adım 5, 2 resimden 1. Garmin Dezl 760LMT Screen Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    • Find and lift the small grey hinge at the end of the ribbon cable.
    • When handling the motherboard, make sure to wear an anti-static wrist strap.
  6. Garmin Dezl 760LMT Screen Replacement, Screen: adım 6, 2 resimden 1. Garmin Dezl 760LMT Screen Replacement, Screen: adım 6, 2 resimden 2.
    • Using a Torx T5 screwdriver, unscrew the four 7mm screws from the back plate of the screen.
  7. Garmin Dezl 760LMT Screen Replacement: adım 7, 3 resimden 1. Garmin Dezl 760LMT Screen Replacement: adım 7, 3 resimden 2. Garmin Dezl 760LMT Screen Replacement: adım 7, 3 resimden 3.
    • Turn the screen over so that it is facing upwards.
    • Remove the front plate of the screen.
    • Lift the screen from its back casing.
Sonuç
Ryan Williams
763 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-2, Passmore Fall 2016 USF Tampa, Team 4-2, Passmore Fall 2016 üyesi
USFT-PASSMORE-F16S4G2
4 Üyeler
2Kılavuz Yorumları
where can one by the replacement screen
tempestrogue - Yanıt Paylaş
Ebay sells these screens replacement - search online for “ZD070NA-03K “ or on google, even amazon sometimes has them. Its a hard to find screen so you will probably only get it from hong kong or china.
neilneves - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 17
Son 30 gün: 72
Her zaman: 2,857
